Silicon Bronze Main Caps and Babbitt
got10carz
Topic author - Posts: 563
- Last Name: Meixner
I have silicon bronze caps to install A crank in T block. Can't seem to be able to flux the caps to accept babbit. Tried different temperatures and flux. Any ideas.
Re: Silicon Bronze Main Caps and Babbitt
what are you using for flux and tinning?
what exactly is happening?
got10carz
1 flux was Eastwood. Using the babbit to tin. I'm not getting the shiney finish that a tinned steel cap gives you.
Babbit is not sticking to surface
I'll assume you're getting things as clean as possible, but perhaps are burning the flux?
Might try these guys for flux made especially for babbit: https://superiorflux.com/products/indus ... bitt-flux/
