Good morning can anyone tell me the what front spindles I have in the attached image the bottom one measures 155mm overall inside bearing to end of the thread 30mm inside diameter of inside bearing with a thread 50mm long and 19mm diameter the spindle attached to the body of the axle measures 127mm in length 34mm inside bearing and 27mm of thread.
Any help greatly appreciated.
						First Project
				chippy74@bigpond.com
Topic author - Posts: 9
 - First Name: Matthew
 - Last Name: Brown
 - * REQUIRED* Type and Year of Model Ts owned: 19## TT ton truck, 19## T Pickup
Chris Instness
 - First Name: Christopher
 - Last Name: Instness
 - * REQUIRED* Type and Year of Model Ts owned: 1915 runabout, T speedster
Re: First Project
Look like early chevrolet, but I am not an expert on spindles. I know Chevrolet spindles have been used on speedsters because of the drop they provide.
Chris Instness
Re: First Project
I should say, the top looks like chevrolet. The bottom is model T.
 - Last Name: Brown
Re: First Project
Thanks Chris I thought it was not original.
