What is the exact size, (length and thread size) of the 4 screws and lock washers that hold the fan blades to the hub?
Thanks!
Fan Blade Hub Hardware Size?
Stephen1915
Topic author - Posts: 430
- First Name: Stephen
- Last Name: Noll
- * REQUIRED* Type and Year of Model Ts owned: 1916 Coupelet
Re: Fan Blade Hub Hardware Size?
1/2" long x 1/4" coarse thread,slotted drive round heads.
Here in Australia, we can use 1/4: Whitworth screws.
Allan from down under
Stephen1915
- Last Name: Noll
Allan, do you mean 1/4-20?
Stephen, I am not into thread counts. 1/4" UNC is the correct size. 1/4" whitworth is an excellent substitute, same number of threads, just a little difference in pitch. The screws, going into aluminium, need to be coarse thread.
Yes, 1/4-20
