AC Brakes and Rich Baughan's linkage
Topic author - Posts: 2921
 - Last Name: Hjortnaes
I have the above and am trying to detI am asermine if they will fit on a car with large and small drums.  Will the AC's fit inside a combination of a large drum and a small drum?  I am also trying to determine from the pictures how the front of the brake system works.  The are nots of pictures from different angles, but If some one has the pieces of Richards setup that they could lay out on the ground in the correct orientation, that would  be great.  Thank you for all your help.  Dave
