Optima 6 volt battery installation
Moxie26
Last Name: Jablonski
Post by Moxie26 » Thu Jan 12, 2023 1:01 pm
Suggestions for installing RedTop battery ???
ChrisB
First Name: Chris
Last Name: Brancaccio
Re: Optima 6 volt battery installation
Post by ChrisB » Thu Jan 12, 2023 1:11 pm
Bob, I have them in 2 of our cars, will take some pictures for you.
Chris
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
Moxie26
Post by Moxie26 » Thu Jan 12, 2023 1:14 pm
Thanks Chris for the quick response ! No quick pictures are expected, but will help within the next few weeks.
Post by RajoRacer » Thu Jan 12, 2023 1:18 pm
I'm also running 2 of them - just have to install on a diagonal & use wood or rubber extensions for clamping - that's how I did mine anyway.
Post by DanTreace » Thu Jan 12, 2023 1:19 pm
Simple board cut with slots for base of battery hanger. Then screw a pair high side boards onto the base, to help keep the narrow battery from tipping. Painting the unit is optional but hides best.
Finally use a wood strap across the Optima battery to lock it in place with factory battery box clamps.
Post by Steve Jelf » Thu Jan 12, 2023 3:23 pm
Depends on the car. 1919 or later I'd use the built-in battery carrier and make a box to fit it. Before 1919 you have to improvise (running board box, under a seat, etc.). I just put the battery for my 1915 runabout in the trunk.
Post by Allan » Thu Jan 12, 2023 4:57 pm
My wide body roadster battery is in a metal running board toolbox. It is clamped down and the side cut out of a small plastic chemical drum acts as an electrical insulator on the top, in case anything else in the toolbox gets loose.
On Henrietta, the running board box is fashioned from an old timber box, complete with wooden lid. It is a snug fit within, so It just sits there. The old, stiff earth lead keeps it tied down.
Dan's hold wooden hold down bar is a neat job in a standard battery carrier.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Thu Jan 12, 2023 5:31 pm
I would like to know the overall height of the 6 Volt Optimum battery as I may be able to use one.
tvw
First Name: Jeff
Last Name: H
* REQUIRED* Type and Year of Model Ts owned: 22 touring
Post by tvw » Thu Jan 12, 2023 5:46 pm
I highly recommend the optima for all 6v applications, you don't want to see my rig to keep it in the battery box :oops:
Moxie26
Post by Moxie26 » Thu Jan 12, 2023 5:55 pm
8.1 " high, 10.06 " long, 3.63" wide
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Thu Jan 12, 2023 5:59 pm
I wish that I bought an optimal battery in 2016 it would most likely still be operating. I went through 2 group 6 volt batteries between 2016 and 2022 i my 23 touring car..
Art Mirtes
Post by Rich Eagle » Thu Jan 12, 2023 6:29 pm
I made a box for a Group 1 tractor battery and the yellow top Optima fit in there like this.
As mentioned, it has been in there since 2001 or so and worked last summer just fine. I didn't check it today.
I would buy some new ones if they are as good as this one has been.
Post by TRDxB2 » Thu Jan 12, 2023 6:37 pm
Art Mirtes
Battery life depends on many things so always hard to compare "battery life". However price wise all depends on what you want to spend at a point in time. The design of the Optima battery has its own unique advantages.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
* REQUIRED* Type and Year of Model Ts owned: 1916 TOURING
Post by BE_ZERO_BE » Thu Jan 12, 2023 6:54 pm
I have one in my '16 Touring.
I installed a Model T battery carrier and set it at an angle like others have.
I also put one under the front seat, behind the gas tank on a '15 Roadster.
Respectfully Submitted,
Be_Zero_Be
I drive a Model T ... Microseconds don't matter :D
Last Name: Hjortnaes
Post by DHort » Thu Jan 12, 2023 6:57 pm
My Optima lasted 11 years and I never charged it thru the winter. I stole a battery box out of the boat and added a piece of 2x8 to hold it in place. $220 to replace it.
JohnH
Last Name: Hunter
* REQUIRED* Type and Year of Model Ts owned: 1926 Geelong Tourer
Board Member Since: 2002
Post by JohnH » Thu Jan 12, 2023 7:30 pm
I made the steel battery box back when I first got the car and used wet lead acid batteries. The only alteration to install the Optima was to add some extra wood packing underneath the battery, and make up the angle iron bracket to hold it down.
Luke
First Name: Luke
Last Name: P
Post by Luke » Sun Jan 15, 2023 2:22 pm
Robert,
I see everyone has focused on the physical in answering your question on 'suggestions for installing [a] RedTop...'
I'd hoped someone would mention ensuring the electrical system is up to scratch, mostly 'cos I didn't want to sound like a stuck record but no-one has so I'll do it :-)
Optima's are great batteries and have a good record for longevity, however they will respond well to a good electrical regime just as any other battery. Thus I suggest that, if you haven't already, it's worth ensuring that all connections are clean and tight, wires are not frayed or burnt, and that you have a regulator installed, not a cutout.
I know JohnH has had a regulator on his car for years, not sure about the others that have responded here but they really are a good thing, and should ensure that the battery isn't overcharged (which will shorten its life). If you only ever do occasional short runs it probably wouldn't make a lot of difference, but should you ever undertake long runs, or drive a lot, it would be a worthwhile change that should help protect your Optima investment.
Luke.
Moxie26
Post by Moxie26 » Sun Jan 15, 2023 3:01 pm
Luke... Thanks for the tips and suggestions, appreciated.
