How to Unstrangle your Kingston L-4... The New Kingston Super Valve - sold out
Post by Scott_Conger » Thu Mar 09, 2023 1:32 pm
Once I have gaskets in hand, I will have 10 of these Super Valves available for purchase. These may be the first of many or the last of a few, depending on response.
Improvements over the stock valve are as follows:
  • throughput is massively greater than a stock valve
  • has a superior Viton tip to seal far better than traditional steel tips
  • cannot get stuck closed, as there is a hook which will be acted upon by the float to ensure complete, on-demand flow
Contact me via email only...no PM's please...
Original design vs Super Valve - With Enhanced Flow Characteristics
South park zephyr
Re: How to Unstrangle your Kingston L-4... The New Kingston Super Valve
Post by South park zephyr » Thu Mar 09, 2023 3:58 pm
I will take one
Scott Francis
Re: How to Unstrangle your Kingston L-4... The New Kingston Super Valve - just a few left
Post by Scott_Conger » Fri Mar 10, 2023 11:18 am
Only a few left
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Fri Mar 10, 2023 2:24 pm
email sent.
Bryant
Franko
Last Name: Franko
* REQUIRED* Type and Year of Model Ts owned: 1914 & 1927
Post by Franko » Fri Mar 10, 2023 7:11 pm
I would also like to have one ! Tim Franko
Bruce Compton
First Name: Bruce
Last Name: Compton
* REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Post by Bruce Compton » Fri Mar 10, 2023 7:27 pm
Great idea Scott. That little hook will sure eliminate the fairly common problem of the viton tip sticking in the seat. Ford even used a similar device to insure complete opening of that passage in the 60's with a steel needle and brass seat.
Re: How to Unstrangle your Kingston L-4... The New Kingston Super Valve - sold out
Post by Scott_Conger » Fri Mar 10, 2023 7:45 pm
All gone
thank you very much
