Wha’ happened?
Topic author - Posts: 754
- First Name: CHARLIE
- Last Name: BRANCA
- Board Member Since: 2010
Wha’ happened?
Just curious. What happened the last few days. Forum was locked.
- First Name: Dennis
- Last Name: Prince
Re: Wha’ happened?
It has been working fine on the left coast. Well at my house any way.
- Last Name: House
Re: Wha’ happened?
Worked well down here in so. central God’s country Texas
Re: Wha’ happened?
They had some major downtime a few weeks ago? Some sort of glitch in a system upgrade. But it has been fine at my place for a couple weeks now.
(Actual timelines subject to greater error as I get older?)
Re: Wha’ happened?
You need to explain what you mean by "locked". Browsers prefer a website to be "locked" meaning it is secured. The "s" suffix on the end of https:// is an indication that the web site is secure with the LOCK ICON. This good and does not prevent access to the siteCharlie B in N.J. wrote: ↑Mon Apr 10, 2023 5:44 pmJust curious. What happened the last few days. Forum was locked.
Just http:// could have a virus looming or not so browsers are starting to restrict access to those --
If you felt "locked out" , that is not being able to access the FORUM then further information is needed. Where you using a smart phone or computer?
Sometimes an Internet Provider may be over protective , do you have a VPN. A VPN is an external Firewall in addition to your own that provides a higher level of security to sites
- Last Name: BRANCA
Re: Wha’ happened?
Locked as in it wouldn’t up date from a few days ago. Hit the page refresher and nothing changed. From I believe Thursday. Never happened before.
Re: Wha’ happened?
Still lots of possibilities - was this the only site with the problemCharlie B in N.J. wrote: ↑Mon Apr 10, 2023 9:12 pmLocked as in it wouldn’t up date from a few days ago. Hit the page refresher and nothing changed. From I believe Thursday. Never happened before.
maybe you can figure it out https://www.google.com/search?client=fi ... 7t+refresh
- Last Name: BRANCA
Re: Wha’ happened?
Happened again but at least I know what it is. The page won’t refresh keeps staying with the same dates and questions on it. The way around is to go to the main page and back to the Forum. Very odd.
Re: Wha’ happened?
It sounds like a memory problem or cache problem and if it is, simply hitting "F5" or "CTRL-F5" will load the latest version of the page.
Re: Wha’ happened?
What brand computer, operating system & browser are you using?Charlie B in N.J. wrote: ↑Wed Apr 12, 2023 7:56 pmHappened again but at least I know what it is. The page won’t refresh keeps staying with the same dates and questions on it. The way around is to go to the main page and back to the Forum. Very odd.
Trying to understand
What "page" are you referring to. By that I mean like the list of discussion on the GENERAL DISCUSSION PAGE
Why are you expecting a change to that page when you do a refresh?
- Last Name: BRANCA
Re: Wha’ happened?
iPad. General discussion page. Expecting a change when refreshing because it always worked. Didn’t work for 3 days.
Re: Wha’ happened?
I don't use an iPad so... but my wife has one. I'll have to see how she uses it. But its impossible to repeat your situation.Charlie B in N.J. wrote: ↑Thu Apr 13, 2023 7:20 pmiPad. General discussion page. Expecting a change when refreshing because it always worked. Didn’t work for 3 days.
Searching the web for answers https://www.google.com/search?q=ipad+sc ... -serp#ip=1
There is confusion in how the respondent interpreted "refresh" vs "update". An "update" discussion are related to app updates nit screen refresh. but suggest you look at some to see if any makes sense.
In one response talked about the screen not refreshing during an update. Also, is this the only web page with the problem?
