TIMING TOOL
Topic author - Posts: 768
- Last Name: S
TIMING TOOL
Is this tool labelled "B" sold by a retailer, or fabricated individually?
________________
**FATE**
**FATE**
- Last Name: van Ekeren
Re: TIMING TOOL
It would have been quicker for you to check the vendors on line catalogs than post your question with photo's here. but to answer your question, Langs, $1.45
- First Name: GG
- Last Name: Gregory
Re: TIMING TOOL
This tool only works for FORD type roller timer’s.
- Last Name: S
Re: TIMING TOOL
Just use the "9:30-3:30" crank pin method and you'll be fine. PM me if you're not familiar with it and I'll describe it to you. Gimme your cell number even and I will call you.
Re: TIMING TOOL
It's pretty easy. No special tool needed.
https://dauntlessgeezer.com/DG97.html
Re: TIMING TOOL
Different strokes for different folks. Steve’s method works pretty good.
The tool shown is real similar to the one that could be homemade in Tinkerin Tips years ago.
- Last Name: Juhl
Re: TIMING TOOL
New Day - great timer....just sayin'
- Last Name: S
Re: TIMING TOOL
I'm a tool geek. I like to collect stuff.
I made something similar out if a paint stick using my other cars timer as a model. I'll grab a mix for you all when I go out to the shop shortly
________________
**FATE**
**FATE**
- Last Name: Humble
Re: TIMING TOOL
Beware, as others have stated, the Ford Service Manual timer gage the vendors sell is ONLY reliable when using a Ford timer and a Ford roller. Other timers have different internals, brushes, or different rollers.
Re: TIMING TOOL
That's the "9:30-3:30" method I plan to talk to him about.John kuehn wrote: ↑Fri May 26, 2023 9:11 amDifferent strokes for different folks. Steve’s method works pretty good.
- First Name: Bob
- Last Name: Middleton
- * REQUIRED* Type and Year of Model Ts owned: 18 roadster 1810 brand X
Re: TIMING TOOL
This tool only works on stock roller timer
Best way is Crank ratchet pin is parallel to the ground this puts piston TDC half the time set and run and fine tune as needed
- First Name: George John
- Last Name: Drobnock
Re: TIMING TOOL
As fate would have it --
Running a New day Timer...this may be helpful:
https://modeltfordfix.com/repairing-a-new-day-timer/
Putting the hobby back another 60 years (c).
- Last Name: S
Re: TIMING TOOL
I get repeated hot starts and my car starts easy. Sunday I'll look at 330-930 pun location. Thanks to all for your help.
________________
**FATE**
**FATE**
