I am going to be relining the brakes on my TT this weekend and have a few questions. I would like to start with the fact that I ordered the TT brake lining set from langs. I believe the part number is 1057-8. Anyways, it came with 2 strips of lining material when each shoe requires its own piece. Should I just cut them down to 12 inches. It looks like I have enough material for each shoe. Secondly, the rivets are the tubular style and not the split style that were on the truck originally. How should I orient the rivets. Should I put the head outside towards the drum or in towards the axle shaft? Also, should I drill holes in the lining for the rivets?
Thanks in advance, Jacob Mangold
Brake Rivets
Jacob Mangold
Topic author - Posts: 207
- First Name: Jacob
- Last Name: Mangold
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT, 1924 TT, 1928 A Coupe, 1976 Firebird Trans Am
- Last Name: Tannehill
Re: Brake Rivets
Jacob I have not done TT brakes but have done 26/7 brakes and i countersunk the tubular rivets. Heads on the drum side with split rivets I don’t know. The brake material is fairly tough & I’d think you may need a special rivet tool. I suppose they’d be set like the bands in the transmission using a tool that roles the split back into the material. Good luck.
Jacob Mangold
- First Name: Jacob
Re: Brake Rivets
Thanks John. I have the little tool to set the rivets. What tools do you need to countersink the rivets and do I need to do that.
Thanks, Jacob Mangold
KBurket
- First Name: K
- Last Name: Burket
Re: Brake Rivets
I used the tool set that Langs sells. It includes a countersink bit.
https://www.modeltford.com/item/2566RVTL.aspx
The product description includes advice about clamping and chamfering the ends of the lining that I followed.
I relined the brakes a couple of years ago and found this photo showing the countersunk hole I had made with the bit from the kit.
Jacob Mangold
- First Name: Jacob
Re: Brake Rivets
I bought that tool as well. I’m not sure it has the same bits though. I will check later today.
