Kevlar band treatment
johnr
Last Name: Delamater
* REQUIRED* Type and Year of Model Ts owned: 1927 Depot Hack
Post by johnr » Sat Jun 24, 2023 2:19 pm
Should Kevlar bands be soaked in oil prior to installation ?
Re: Kevlar band treatment
Post by John kuehn » Sat Jun 24, 2023 2:33 pm
I did let them soak for a while for my 24 Coupe. I don’t know about anybody else. It won’t hurt anything since they run in oil anyway. But others will have other opinions as they always do I’m sure.
Post by Scott_Conger » Sat Jun 24, 2023 2:36 pm
That just makes an aggravating job more aggravating! ;)
I install dry onto the steel bands and insert dry into the transmission (with hog's head removed). Then after hog's head is securely assembled, I VERY SLOWLY pour 2 quarts of oil OVER the bands and the remainder into the normal oil filler up front. Then idle the engine for about a minute and then walk away from it for a day.
Everything is fine the next day
Post by speedytinc » Sat Jun 24, 2023 4:54 pm
I do it the same as Scot says. Overnite the oil wicks up into the band to totally soak it.
P.S. I also leave the bands in a loose setting until just before starting. Then do a rough tightening.
Post by Allan » Sat Jun 24, 2023 11:19 pm
I install the linings dry onto the bands, and then soak the lot in oil prior to fitting to the trans.
Nv Bob
First Name: Bob
Last Name: Middleton
Post by Nv Bob » Sun Jun 25, 2023 1:26 am
Dry and refilling the engine oil threw trans door
