Need blker. Distributor
Topic author - Posts: 239
- First Name: Philip
- Last Name: Thompson
If anyone has any info on the jess. blker. Belt drive distributor let me know
Re: Need blker. Distributor
I meant jess. Blker.
- First Name: DAN
- Last Name: MCEACHERN
Used a Chevy Vega 4 cyl distributor, a pair of timing belt pulleys- one on the dist shaft and one on the cam nose. A simple bracket mounted the distributor horizontally with the cap to the rear. Pretty sure a few of them are out there still running.
I think I have one I have to get some pulleys and a belt
- First Name: Brent
- Last Name: Terry
- * REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1915 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
- First Name: jeff
- Last Name: cordes
- * REQUIRED* Type and Year of Model Ts owned: 25
I copied the design. It was a cheap solution for a decent ignition.
does anyone have any information on these units i have parts but not the bearings
- First Name: Billy
- Last Name: Wade
It sounds like you are describing a custom setup for a Chevy Vega 4-cylinder engine that uses a timing belt pulley system to drive the distributor. It's interesting to hear that this setup is still being used by some individuals and may be a viable alternative to traditional distributor setups.dumb ways to dieDan McEachern wrote: ↑Mon Aug 22, 2022 8:17 pmUsed a Chevy Vega 4 cyl distributor, a pair of timing belt pulleys- one on the dist shaft and one on the cam nose. A simple bracket mounted the distributor horizontally with the cap to the rear. Pretty sure a few of them are out there still running.
yes i have the bracket and a badly worn vega dist. made by jess blker. i bought a new dist.
but i would like to see how jess did the bearing
This is a 009 VW version (By Bob Doris, AZ on Wednesday, May 23, 2018) of the Jess Blaker distributor https://www.mtfca.com/discus/messages/8 ... 1536630758
- First Name: Les
- Last Name: Schubert
Gear driven.
Did you cast the body?
- First Name: Les
I machined it from two pieces of aluminum and then welded
- First Name: Les
For the shaft and bearings I bought what is referred to as a “water pump shaft “
- First Name: Les
The “traditional” approach to timing a automatic advance distributor is teeing a vacuum gauge into the system and adjusting the timing for maximum vacuum at idle
Thanks les. My question is would I be better of with manual advance with this setup
