KC Warford ratios vs Muncie
Topic author - Posts: 404
- First Name: Dennis
- Last Name: Prince
Howdy, I am trying to find out how the gear ratios of a Muncie and a KC Warford compare. I am looking for the ratio of the transmission not the final ratios at the rear diff. Any help would be greatly appreciated. Thanks Dennis
Re: KC Warford ratios vs Muncie
Dennis, Layne, the makers of the KC Warford can help. There are different ratios for different applications. I have seen a chart illustrating these but cannot reference it.
- Last Name: Saylor
I have seen the KC Warford ad in the Vintage Ford showing the different ratios. For the Muncie, you can turn the input shaft and count the output revolutions to get the ratio.
- First Name: craig
- Last Name: leach
This may help.
Craig.
The KC Warford add has their gear ratiosCraig.
- Last Name: Prince
Thank you all for the ratio info, it is what I was looking for.
