Hershey Turtle Deck Trade or Buy?
Carter
First Name: David
Last Name: Carter
* REQUIRED* Type and Year of Model Ts owned: 1925 Roadster, 1926 Modified
Board Member Since: 2010
Post by Carter » Fri Sep 22, 2023 10:02 am
Hello all, I've got an earlier turtle deck on my '22 Runabout right now and would like to replace it with a more correct one (flat handles, notched for battery), and hopefully better matched to the car as well. Would ideally like to trade, but would also buy the right one. Pics attached of what I've got.
Last Name: Tannehill
Re: Hershey Turtle Deck Trade or Buy?
Post by JTT3 » Fri Sep 22, 2023 11:36 am
David, just from a cost savings standpoint you may also consider just a trade for the complete top/lid including hardware from someone that needs the early style handles you have. For that matter someone just may have the lid alone. Shipping would really be a possibility then. Might want to include looking for lid in your tile. Best John
Last Name: House
Post by George House » Sat Sep 23, 2023 10:52 am
John, respectfully, David has a ‘14-‘16 (or ‘17,18) turtle deck w/o provision for a battery offset in the front panel and he also needs this front panel along with the pressed steel latches for his ‘22.
Post by JTT3 » Sat Sep 23, 2023 11:21 am
George you’re absolutely right looking at the pictures again I can see it may have a front panel, thought it was missing in which case he could make it work, forgot about that cut out at the floor. Don’t have one with that type turtle deck that needs a battery.
Carter
First Name: David
Last Name: Carter
Post by Carter » Mon Sep 25, 2023 8:07 am
John, thanks for the reply, and George, thank you for the additional information as to why I'm looking for another deck. By the way, George, did you get my email reply?
Thanks!
Dmueller1916
First Name: Don
Last Name: Mueller
* REQUIRED* Type and Year of Model Ts owned: 1916 touring
Post by Dmueller1916 » Mon Sep 25, 2023 8:20 am
I think I have a ‘24 Turtle Deck that I will be taking to Hershey. I will be in the Orange Field, spaces OBG 29-31.
Carter
First Name: David
Last Name: Carter
Post by Carter » Mon Sep 25, 2023 8:31 am
IMG_0166.jpegI think I have a ‘24 Turtle Deck that I will be taking to Hershey. I will be in the Orange Field, spaces OBG 29-31.
Thank you for the reply, but that won't work for me, I need the '19-'22 style. Good luck!
