26-27 accessory tail light wiring and switch
Topic author - Posts: 28
- First Name: Will
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 26 Runabout
I have the accessory tail light and license plate bracket which I would like to install/. I need the switch that attaches to the brake pedal. How can I make one? Also how is it wired?
Re: 26-27 accessory tail light wiring and switch
Correct repop style attaches on the Bendix cover. Langs #3158XS
- Last Name: Humble
Easy to run a wire from the starter switch to the brake light switch, then a wire from the stop light switch following the tail light wire back to the stop light
- First Name: Will
- Last Name: Brown
Thank you. I didn't know that Lang's had the switch.
A few use the 1928/29 Model A brake light switch mounted under the bottom band inspection plate screw with a bent wire connecting it to the brake pedal.
- Last Name: Matthiesen
Besides the options above there is the option of using the lever type brake lite switch as used on a 1949-50 Chevrolet. Mount it such that the forward motion of the brake pedal depresses the lever attached to the under side of the floor board or a homemade bracket. If you go with this switch you can buy a new switch from The Filling Station in Lebanon Oregon.
- First Name: Terry
- Last Name: Woods
I think Snyder's and possibly Chaffin's has it too. The repos made years ago, gave a lot of trouble. I understand that the current ones are made in USA and are of better quality.
- Last Name: Zibell
You can also check with Birdhaven to see if they are making the Fun Projects switch. It is really easy to install and reliable.
1926 Tudor
Many variations & ideas viz Google search https://www.google.com/search?client=fi ... RJXYGWCXNM
