F.S. Large Warford collection
Nate22huckster
Topic author - Posts: 174
- First Name: Nathan
- Last Name: Fahrni
- * REQUIRED* Type and Year of Model Ts owned: 1922 huckster, 1925 tudor, 1926 TT dump truck, 1927 tudor
I collected these warford parts from swap meets and auctions with the intent of building a speedster but ended up going the more authentic route and built a huckster instead. Currently I’m restoring a Tudor sedan as I now need a back seat for the whole family to be able to ride. The sale of these parts will go towards an upholstery kit for that.
Warford group #1: one complete aluminum case warford transmission, both shortened radius rods, one shortened driveshaft housing and one shortened driveshaft. I bought these as a group about 15 years ago at a swap meet. I want to sell these as a group $1500 as is, local pick up only.
Last edited by Nate22huckster on Fri Oct 06, 2023 6:51 pm, edited 1 time in total.
Nate22huckster
- Last Name: Fahrni
Re: F.S. Large Warford collection
Warford group #2: one incomplete aluminum case warford transmission, there are some gears inside. All of the gears in the two trays are included in this lot. Also included is a very nice complete shift tower. And lastly an adapter to shorten a stock T driveshaft housing. $800 as is, local pick up only.
Nate22huckster
- Last Name: Fahrni
Re: F.S. Large Warford collection & accessories
Warford group #3: one empty aluminum case warford transmission, there is some damage, it’ll need repaired. Also included is a very nice bare shift tower. $200 as is
Grntea
- Last Name: Tagert
- * REQUIRED* Type and Year of Model Ts owned: 1926, 1925, 1923, 1921, 1918
Email sent
Nate22huckster
- Last Name: Fahrni
to the top please
tvw
- Last Name: H
- * REQUIRED* Type and Year of Model Ts owned: 22 touring
To the top for Nate, a great seller. Group # 1 is a complete set to get you a Warford without sacrificing your original parts.
Nate22huckster
- Last Name: Fahrni
To the top again please.
Thanks Jeff!
Update: Group # 1 is pending, and I sold two gears out of group # 2. Everything else is up for grabs still. I'll post updated pictures of what's left when payment comes through for group #1. The extra gears and loose pieces-parts would be great to have on hand for someone running an original Warford or for someone rebuilding one. The driveshaft adapter is a great piece too, makes for easy shortening of your driveshaft tube.
Thanks MTFCA
Thanks Jeff!
Thanks MTFCA
1977f250
- First Name: james
- Last Name: scott
- * REQUIRED* Type and Year of Model Ts owned: 1926 touring
do you still have any of the gears left thanks travis
themadmodelt
- First Name: Brian
- Last Name: Sullivan
Email sent
1977f250
- First Name: james
- Last Name: scott
sorry im new to this did you send me a email thanks travis i might have messed up my email address i have a warford that has a couple bad gears
Nate22huckster
- Last Name: Fahrni
Update:
Group #1 is sold pending payment
I have also sold 4 gears out of group #2
I will try and get updated pictures of what is left uploaded soon.
James, What gears in particular are you looking for?
1977f250
- First Name: james
- Last Name: scott
thank you for your patience im going to check my trans out this weakend to see what gears i need i think the gear for low range i have the top off just have not had time to check it out thanks travis
Nate22huckster
- Last Name: Fahrni
Update: everything is sold except group #1 (the complete warfard, shortened drive shaft and housing and radius rods. The sale of those items is still pending at the moment.
Nate22huckster
- Last Name: Fahrni
Update: everything is sold. Thanks MTFCA
