Storing inner tubes
South Park Zephyr
Last Name: Francis
* REQUIRED* Type and Year of Model Ts owned: 22 Runabout
Board Member Since: 2022
Storing inner tubes
Post by South Park Zephyr » Fri Nov 10, 2023 2:07 pm
I was wondering if there is a proper way to store new inner tubes that will keep the viable?
At this time they are folded and secured with a rubber band.
Thanks,
Scott
Re: Storing inner tubes
Post by speedytinc » Fri Nov 10, 2023 2:14 pm
I put them in a zip-lock bag with baby powder. Remove as much air as possible.
Even older salvaged tubes keep for decades.
Leave a similar new or old tube to the air, it will crack @ the seems & folds in a few months.
Post by RajoRacer » Fri Nov 10, 2023 2:21 pm
I store mine in the shop, in the dark, aired up a bit.
Last Name: House
Post by George House » Fri Nov 10, 2023 3:11 pm
I’m in the zip lock bag w/baby powder crowd. But I Don’t store them in my shop. I leave them in the closet of one of the guest bedrooms. My uninsulated shop has been 120* in the summer. That’ll make them crack.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Fri Nov 10, 2023 3:16 pm
Folded or rolled, they seem to crack along the unadvoidable flat edge, at least mine have. Probably best is lightly inflated with nitrogen and in a dark cool place, but....
Last Name: Wrenn
Post by TWrenn » Fri Nov 10, 2023 4:01 pm
I don't do nitrogen but do believe just enough air to inflate, store in basement. Seems to be no different then than inside a tire with varying temperature swings wouldn't it? Keeping them folded I think is definitely not a good idea.
Russ T Fender
First Name: Val
Last Name: Soupios
Post by Russ T Fender » Fri Nov 10, 2023 5:07 pm
I keep them partially inflated in old tire casings in my basement where the temperature is fairly stable.
NHUSA
First Name: Fred
Last Name: Dimock
* REQUIRED* Type and Year of Model Ts owned: 1919 T with Mifflinburg Suburban body
Post by NHUSA » Mon Nov 13, 2023 9:24 pm
I put the tubes in the old tires, slightly inflated them, and wrapped them in stretch wrap.
NH - Where I used to live - not the carburetor ! :lol:
Cordes_jeff
First Name: jeff
Last Name: cordes
* REQUIRED* Type and Year of Model Ts owned: 25
Post by Cordes_jeff » Mon Nov 13, 2023 10:08 pm
I fold them and put them in used plastic grocery bags. I double bag them and put them in a cabinet. I've stored them for decades like this.
First Name: craig
Last Name: leach
Post by Craig Leach » Mon Nov 13, 2023 11:53 pm
Air conditioning only in the original package in the house house. I find a reliable local supplier & try not to store them
any longer than I have to. Used I store aired up inside the house also. ( do have 21" on my Ts so I can get tires & tubes
from the model A suppliers also.)
Post by Allan » Tue Nov 14, 2023 2:55 am
It does depend a bit on the tubes themselves. I store my old Olympics, folded and stowed in a carton, in my cellar which is at a constant 72 degrees.
Modern tubes don't do a very good job of holding air, so it is a moot point trying to store them anyway.
Allan from down under .
South Park Zephyr
Last Name: Francis
Post by South Park Zephyr » Tue Nov 14, 2023 8:38 am
Thank you to everyone.
It is good to hear the different ways that have been successful.
Scott
