Stevens T-180 Generator Gear Puller
Topic author - Posts: 382
- First Name: Nikolaus
- Last Name: Martin
I picked up this puller, which is missing the stand and handle/punch. Could anyone with a good one measure exact dimensions of the punch so that I get it right? Thank you.
Re: Stevens T-180 Generator Gear Puller
I've been collecting Stevens tools for 30 + years - never have had the pleasure of finding the Stevens stand - I have a copy of the Allen holder. I have the puller & will measure my handle for you.
- Last Name: Martin
Thanks! It doesn’t look like there is a handle/punch in the one in the box either! Out of curiosity, what tool has the Hassler arm been turned into?
The handle's in the top tray - I turned the Hassler arm into a peining jig for the gear pin.
Mine measures 0.310 in diameter - 4.50" in length - knurling is 1/2" wide & 2" from either end.
- Last Name: Martin
Thanks, that’s interesting. The one in the catalog has a punch for the gear pin built in. Maybe they figured out this was a clumsy setup, or maybe yours lost its original too. My handle hole is 5/16”. There is a square dent like some locknuts have, presumably to create an interference fit for the punch.
- First Name: Ed
- Last Name: Fuller
- Board Member Since: 2012
Wow Steve! You have all of the coolest toys….I mean tools!
- Last Name: Martin
Here’s the only one I found online, and it appears to have the reduced-diameter punch part broken off at right.
- First Name: Jerome
- Last Name: Hoffman
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring, 1924 Roadster, 1923 Speedster, 1923 Racer, 1921 TT Wood Cab
When I picked up mine, it was also missing the punch. Had I seen this ad first, I would have better understood that it did not need a handle. A post with a picture and some dimensions would be great if anyone has the punch. J
model_t@swbell.net
Projects: 1916 Speedster - Dec 15', 1921 TT Wood Cab and Bed, 1923 Racer ( My dad's), 1923 Speedster (started in HS)
1924 Roadster - Dec 23' (eBay) and 1924 Touring - June 24' ( Dad's Car been in the family since 1948)
I did not notice the "punch" end in the catalog illustration - I'll look mine over again but ?
- First Name: Trent
- Last Name: Boggess
This is a NOS Stevens T-180 I found at Hershey this year:
Respectfully Submitted,
TrentB
TrentB
- Last Name: Martin
Wow! Could you give us the two diameters and two lengths?
Nice score Trent !!! First Stevens base I've seen.
- First Name: Trent
Certainly.
The overall length is 5.525 inches.
The major diameter is .328 and is about 4.440 inches long.
The minor diameter is .162 and about 1.112 inches long.
The lengths of the major and minor diameters do not quite add up to 5.525 inches because of the transition from the minor to major diameters.
TrentB
TrentB
- Last Name: Martin
Thanks! That’s really helpful.
Trent - is the handle/pin driver removable from the body ?
- First Name: Keith
- Last Name: Gumbinger
Trent, You lucky dog!!!!
Keith
Keith
