FS ---- T, TT and AA parts
				26modeltt
Topic author - Posts: 72
 - First Name: Jack
 - Last Name: Leonhardt
 - * REQUIRED* Type and Year of Model Ts owned: 1926 Model TT Dump Truck w/ Weaver Model G 3 ton capacity wrecker boom.
TT 3 rear shackles $90.00, T/TT steering column $25.00, TT brake drums $60.00 pr., A spare tire brkt./mount $75.00 pr. and AA hub caps $50.00 pr. Plus shipping. Text 920-two two six-1005.
				Andy ruffles
 - Last Name: Ruffles
 - * REQUIRED* Type and Year of Model Ts owned: 1912
Re: FS ---- T, TT and AA parts
Hi i will take the rear shackles
				26modeltt
 - First Name: Jack
Andy,
Sent you a private message, also an email to one your fellow "T" owner's "Down Under" for a possible combined shipment to Australia and save $$$$$.
Regards,
Jack
Regards,
Jack
				Andy ruffles
Jack
Do you have any truck rear Hyatt bearings as well.
				26modeltt
 - First Name: Jack
Andy,
I have multiple #1019 outer axle bearings, #1050 Worm thrust bearing collars, #1051 Worm thrust ball and separator assemblies, #1046 Worm roller bearings, #1018 Axle shafter inner ball bearing assemblies, #1113 brake drums, #1048 Worm roller bearing sleeves and more. No rust/corrosion.
Regards,
Jack
Regards,
Jack
				Andy ruffles
Jack
Sent you a private message.
Regards Andy
Regards Andy
				26modeltt
 - First Name: Jack
Andy,
Sent email w/ photo attachments to you.
Thanks,
Jack
Thanks,
Jack
				26modeltt
 - First Name: Jack
SOLD to Jeff ---- Model A Spare Tire Brackets.  Thank you Jeff.
