What Oil Should I Use in My Fip Top Oilers?
BLB27
Topic author - Posts: 892
- First Name: Bruce
- Last Name: Brakke
What oil should I use in my fip top oilers on my 1927 coupe?
- Last Name: Humble
Re: What Oil Should I Use in My Fip Top Oilers?
Any engine oil will do.
JBog
- First Name: Jason
- Last Name: Bogstie
I use bar chain oil. It sticks better.
Maybe so BUT, does it migrate better ?
Tadpole
- First Name: Tad
- Last Name: Glahn
Anything that lubricates can get the job done, I use maple syrup because I like the smell.
- First Name: Dallas
- Last Name: Landers
I use CBD oil. Eats more gas but the front end is calm with no shaking.
Just funnin. I use bar and chain oil also.
havnfun
- First Name: Joe
- Last Name: Kowalczyk
Any motor oil, it takes on a rebuilt front axle assembly overnight to lubricate the spindle bushings top and bottom. You should see oil spots under the spindle bolts or the lubricant isn’t lubricating the bottom bushing.
Regards,
tvw
- Last Name: H
- * REQUIRED* Type and Year of Model Ts owned: 22 touring
Dallas Landers wrote: ↑Fri Dec 22, 2023 2:26 pmI use CBD oil. Eats more gas but the front end is calm with no shaking.
I use any motor oil which usually means 0 or 5w something, which really runs thru fast. I bet the bar oil works good tho.
Chain bar lube or 600W is my go to most of the time.
Bill Anziani
- First Name: Bill
- Last Name: Anziani
- * REQUIRED* Type and Year of Model Ts owned: 1924 Coupe
I use the 600 weight also
I refill the oilers about twice a week
Joe Bell
- First Name: Joe
- Last Name: Bell
Chainsaw bar oil, nice and sticky.
Charlie B in N.J.
- First Name: CHARLIE
- Last Name: BRANCA
- Board Member Since: 2010
I concur with the majority: chain saw bar oil.
I have 2 chain saws I use here on the place and the bar and chain oil is the best oil to use. It doesn’t take a lot and the stickiness and weight helps it stay in place.
Art M
- First Name: Art
- Last Name: Mirtes
Ii have been using chainsaw oil for about 3 years. I didn't know anyone else who uses it until now. I apply oil every 100 miles as recommended in literature.
Art Mirtes
Art Mirtes
Roger Byrne
- First Name: Roger
- Last Name: Byrne
- * REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo Open Runabout, 1914 Touring, 1912 Speedster (in progress) 1927 Touring
I agree with the majority view and use bar oil on all of them . . . EXCEPT on the spindle oilers. If the bushings are new/tight, I use regular engine oil (10-30). If they are worn, then they get bar oil too.
Preserving Mechanical History for Future Generations since 1965
I often use Amsoil Synthetic R&O, AW gear and bearing oil ISO-680 (RPC). It is thick but flows well. I bought it to use in my Warford and use it in T rear ends as well as my '23 White trans and rear end. I like it but also use Pennz 10-30 sometimes.
- First Name: craig
- Last Name: leach
I have found gear oil to work well, I have even saved it when I change the rear end oil.( if it's clear of metal flakes) the most important
thing is to oil them as most don't seem to do it very often! Don't forget all the other lube points. For some reason I'm always short of bar oil.
Merry Christmas all.
