How tight should the kingpins be?
Mopar_man
Last Name: Govoni
Post by Mopar_man » Sat Jan 20, 2024 7:00 pm
Take a look at the video and tell name what you think?
https://youtu.be/sw-Hur18EqE
Re: How tight should the kingpins be?
Post by RajoRacer » Sat Jan 20, 2024 7:32 pm
I tighten the bolt snug already being oiled up - the nut just locks the adjustment but you can over-tighten the nut.
Last Name: Wrenn
Post by TWrenn » Sat Jan 20, 2024 7:38 pm
From what he is showing looks ok to me.
Moxie26
Last Name: Jablonski
Post by Moxie26 » Sat Jan 20, 2024 7:47 pm
The kingpin does thread into the bottom of the axel for tightness, whereas the the cotter pinned nut locks in the adjustment.
Mopar_man
Last Name: Govoni
Post by Mopar_man » Sat Jan 20, 2024 8:34 pm
Thanks for the input. I'm thinking this will be better than what I had.
Post by DanTreace » Sat Jan 20, 2024 8:37 pm
Final check of tightness will occur when wheel bearings and wheels are mounted and steering connected.
You’ll know the kingpins are too tight when the front is jacked up and you can’t turn the steering wheel :lol:
Moxie26
Post by Moxie26 » Sat Jan 20, 2024 8:38 pm
Don't forget to oil everything in the suspension
Post by Allan » Sat Jan 20, 2024 10:12 pm
My thought is the kingpins should not be tight at all. The thread in the axle allows the bolts to be drawn down enough to eliminate up and down play between the eyes of the axle. That adjustment should not cause drag. Similarly the bolts in the bushes should not drag either. A T steering mechanism needs all the help it can get. Unnecessary load it does not need.
Allan from down under
Mopar_man
Last Name: Govoni
Post by Mopar_man » Sat Jan 20, 2024 10:56 pm
Allan, I get what you are saying. I'm jut trying to find that happy spot between too loose and too tight. I'm thinking if they are too loose they can start to ware out. Too tight and there is too much friction.
Chris Barker
First Name: Chris
Last Name: Barker
Post by Chris Barker » Sun Jan 21, 2024 8:54 am
A couple of points:
1. Some friction is good. It provides damping to stop the wobble instability that Ts tend to suffer at about 12 mph. I think one of your spindles is too loose.
2. tightening the top of the spindle will give you a bit more friction, but then when you tighten the bottom lock nut, it pulls the spindle down further because the threads have a little freedom, so you need to adjust top and bottom, trial and error, until it's fine when the locknut is tight. And of course the split pin holes have to line up!
Last Name: Wrenn
Post by TWrenn » Sun Jan 21, 2024 9:14 am
I would think once you start feeling "that resistance" on your bicep it's starting to tell you enough is enough. I've re-worked at least 4 front ends, tightened em "pretty tight feeling in my arm", one spindle barely could turn but once all put together and on the ground it turned with ease with the steering wheel. As someone also said, just a reminder, before you slide the king pin bolt in, be sure to lube it well first top to bottom. I actually smear some lubriplate on mine first. It's gotta help I'm sure.
Wingnut
First Name: William
Last Name: Reep
* REQUIRED* Type and Year of Model Ts owned: 1924 roadsters, 1926touring
Post by Wingnut » Sun Jan 21, 2024 12:31 pm
If you think it's too tight then back it of a smidge. Allen has it right, 30 years as a UPS mechanic has taught me to fly by the seat of my pants ,if you feel good about it then run it, easy enough to readjust after a few go rounds .
First Name: craig
Last Name: leach
Post by Craig Leach » Sun Jan 21, 2024 4:58 pm
The kingpin only needs to be tight enough to keep it from rotating or moving up & down. It should not be used to adjust the endplay in the
spindle, that is the function of the machineing of the thrust end of the bushing. If you tighten the kingpin bolt till it creates resistance to
the spindle it is tight enough to stop oil from getting in to lubericate the thrust surfaces which will wear them till oil will get there. What
would be the point??? By 1930 almost all MFGs had gone to a yoke style spindle & a tapered pin locked kingpin.
Mopar_man
Last Name: Govoni
Post by Mopar_man » Sun Jan 21, 2024 7:42 pm
Thanks again for all the input. I'm going to try them out and see. If I have to loosen them up a bit I can. I do want oil to get on the thrust surfaces.
