Floating Hubs / Safety Hubs
dr1960
Topic author - Posts: 151
- Last Name: Ruedy
- * REQUIRED* Type and Year of Model Ts owned: 1915 Model T Runabout Pickup
There appears to be a few options on the floating safety rear hubs. Different bearing types, roller, needle, and ball bearings. Different suppliers have slightly different approaches. I am considering them for my 1915 Model T. What advice can you give me or experience you can share on the various options? Thanks.
David - Yukon, OK
Re: Floating Hubs / Safety Hubs
Contact Dan McEachern - IMO - his design is the best !
Waste of time!
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Only right before your axle breaks Larry! after that, well..................
kelly mt
- Last Name: Kelly
I run safety hubs on two of my T's that I tour in. I drive many miles every year on and off the pavement and see them as a big safety improvement.
Ford went to floating axles on the A model. Can't imagine them doing that if it was a waste of time. After 15 million T's, there must have been a reason for the change.
Glen McConachie
- First Name: Glen
- Last Name: McConachie
- * REQUIRED* Type and Year of Model Ts owned: A few 1926 - 27 Tudors and coupes
I have found them very helpful, first time we broke an axle, it
meant we could tow it back home after it snapped a block from home and didn't destroy the guard or bodywork, the second time when a driver hit us side on at 40 km/h after ignoring a stop sign, the axle housing has compressed but we could still limp it to get it onto a trailer, the bodywork has suffered this time but it could have been a lot worse.
dr1960
- Last Name: Ruedy
Sent you a PM Dan for info.Dan McEachern wrote: ↑Mon Feb 05, 2024 1:08 pmOnly right before your axle breaks Larry! after that, well..................![]()
David - Yukon, OK
Philip
- First Name: Philip
- Last Name: Thompson
they work great and have a nice big sealed bearing here is how i make mine these are not finished but
you can see the design
Phillip, I use a similar design to make floating rear axles for my T's, but do not make them into a true safety hub.
I presume the unmachined tubular part of your spiggot goes into the axle housing, the bearing goes over it, and is retained on it by the thin flange screwed in place. Then this sub assembly is fitted in the carrier to be fixed to the wheel. Your photos of the unfinished set-up raise a few questions.
How do you fix/retain the spiggot in the axle housing and seal around it?
I presume the 6 larger holes in the carrier coincide with the 6 hub bolts. If so, does the countersink mean you use a countersunk bolt with a nut on the outside of the wheel?
What purpose do the six smaller intermediate countersunk holes serve?
I may have to adjust my work to make improvements.
Philip
i use 2 big o rings to seal it then t put a groove that lines up with the grease cup. tap the hole in
the grease cup and put a set screw there cap then hides it. the extra holes are for holes i tap in the inner
hub flange.
hub flange.
Philip
i also just tap the holes for the thru bolts on my current design. bolts go in from outside.
better but you see the hex heads but less clearance issues and you can check tightness
Philip
on these i used chamferd nuts but i didnt like them
AdminJeff
- Last Name: Stevenson
I second this. I installed Dan's safety hubs and am VERY happy with them. What is your life worth? That's the question to ask if you are on the fence about these...
Assistant WebSite Admin
www.modeltregulators.com
www.modeltstarters.com
Will
- First Name: Will
- Last Name: Copeland
- * REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
I installed Dan's hubs on my 1919 touring over 12 years ago and never looked back.
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
