Early vs late rear end carrier?
Topic author - Posts: 705
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
Just curious I have 2 rear end carriers is one just a earlier version which is which?
- Last Name: Eyre
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring 1914 Touring and Roadster 1915 Touring 1926 Roadster
Re: Early vs late rear end carrier?
The one with the studs is earlier. The late ones have bolts all the way through both sides.
The lip that the thrust washers ride in is really worn and undercut on both. The thrust washer would have been held in place with two pins. Looks like the pins sheared, allowing the steel thrust washers to cut into the flange.
Early or late, they both fit/work the same, only difference, the early needed a tie wire between the 3 studs and late bolt type used cotter pins.
- First Name: Karl
So what year is the change over?
Bolt began being used in 1922 instead of stud.
- First Name: Robert
- Last Name: Brough
- * REQUIRED* Type and Year of Model Ts owned: 1915 War Wagon 1927 Depot Hack 1927 TT
I prefer the early rear end carrier, myself.
What? Oh, you mean a Model T?
Never mind.
Never mind.
A bunch of old cars
Sometimes they run.
Sometimes, they don't.
A bunch of old cars
Sometimes they run.
- Last Name: C
The rear end above is just someone else's problem.
