OLD PHOTO - BROKEN AXLE AND HOUSING
Topic author - Posts: 1527
- First Name: Jay
- Last Name: Buscio
- * REQUIRED* Type and Year of Model Ts owned: 1913 speedster 1915 roadster pickup 1915 touring, 1927 speedster
Re: OLD PHOTO - BROKEN AXLE AND HOUSING
Ohhhh. Not again...
https://www.mtfca.com/phpBB3/viewtopic.php?f=2&t=41349
The general consensus is that it was caused by...
- Being Canadian
- No oil
- Broken axle shaft as root cause
- Broken housing as root cause
- Fat people
- Failed rivets
- Pot hole
- Axle gear came off
- Poor trailering practice
- Sabotage
- Improperly installed bearing sleeve
- Jacking it under the diff case
- Being Canadian
- No oil
- Fat people
- Failed rivets
- Pot hole
- Sabotage
Last edited by Jerry VanOoteghem on Fri Feb 16, 2024 2:21 pm, edited 2 times in total.
Stop laughing! If it had happened to you, you would be crying
- Last Name: Wrenn
We just be "showing our age"...ha ha. This is the second one that got a "rerun"...remember the roadster with the guy 'n girl in it with the outhouse way out in the background? It made two rounds also!!Norman Kling wrote: ↑Fri Feb 16, 2024 2:32 pmStop laughing! If it had happened to you, you would be crying![]()
No, I'm pretty sure I'd be laughing too. Not happy, but laughing...Norman Kling wrote: ↑Fri Feb 16, 2024 2:32 pmStop laughing! If it had happened to you, you would be crying![]()
- Last Name: Wrenn
Laughter IS the best medicine, aint it Jerry!!Jerry VanOoteghem wrote: ↑Fri Feb 16, 2024 2:45 pmNo, I'm pretty sure I'd be laughing too. Not happy, but laughing...Norman Kling wrote: ↑Fri Feb 16, 2024 2:32 pmStop laughing! If it had happened to you, you would be crying![]()
You got it Tim!! I'm not gonna be cheated out of a laugh just because it's at my own expense.TWrenn wrote: ↑Fri Feb 16, 2024 3:02 pmLaughter IS the best medicine, aint it Jerry!!Jerry VanOoteghem wrote: ↑Fri Feb 16, 2024 2:45 pmNo, I'm pretty sure I'd be laughing too. Not happy, but laughing...Norman Kling wrote: ↑Fri Feb 16, 2024 2:32 pmStop laughing! If it had happened to you, you would be crying![]()
Norm![]()
Not medicine for a broken axle! A lot of elbow grease and money and good jacks needed to fix this problem and if on a tour need a winch to get it on a trailer, maybe even a crane for the back of the car.
