FS ACCESSORY OIL BREATHER CAP (SOLD)
Topic author - Posts: 4362
- Last Name: Chaffin
Accessory flip-top oil breather cap. Cast aluminum. Price is $75.00 with free domestic shipping. Mark Chaffin (951) 805-0928
- First Name: DAN
- Last Name: MCEACHERN
Re: FS ACCESSORY OIL BREATHER CAP
Mark- does this fit the early or late timing cover? I think there is a difference.
Smaller of the two. Height wise.
- First Name: Terry
- Last Name: Woods
I didn't realize there was a difference. I'd better check my APCO oil filler. If it doesn't fit a late (26-27) timing cover, I'll have one for sale.
- First Name: DAN
On the early cover, the 3/8 bolt pretty much goes thru the center of the fill hole. On the later generator covers, that bolt is offset to the inner edge of the fill hole. I'm not sure what Mark is referring to above. The fill holes are pretty much the same size regardless of gen or non-gen cover............
This is a Tim Morsher cast reproduction. I believe it may fit either style.
Re: FS ACCESSORY OIL BREATHER CAP (SOLD)
Sold to Shannon. Thank you
- First Name: David
- Last Name: Meier
- * REQUIRED* Type and Year of Model Ts owned: 1919 Model T Touring
so, this replaces the current oil filler cap? Do you know if it would be for a 1919 Model T Touring?
