26 roadster upholstery
fordt
Topic author - Posts: 165
- First Name: Rob
- Last Name: Trippet
- * REQUIRED* Type and Year of Model Ts owned: 27 Roadster PU
Getting back after the roadster and mocking up the seat back and hip panels from Classtique. Is there a certain/preferred height, either above/even/below the top of the back of the seat bucket where the backrest should hang? Also, should there be some added padding to the hip panel armrest top?
Re: 26 roadster upholstery
If you got your upholstery from Classtique I would call them for advice. I’m sure they could give you a good answer.
- Last Name: Strange
Check out this video from Classtique. See how the top of the spring pack is about level, or maybe just a bit below the top of the tack rail. That way, when the burlap gets pulled taut, it creates a flat "floor" for the cotton padding to sit on.
https://www.youtube.com/watch?v=75x68vcE8go&t=6s
fordt
- First Name: Rob
Yup, I saw that, so I was at least trying to keep the corners level with the tub…thanks!
rickd
- First Name: Rick
- Last Name: Duquette
Rob, another upholstery resource for you to check out-"One Who Collects" on youtube. He does the interior and top on a 25 runabout. Interesting tip he provides is attaching fabric with hogrings into the open top area of the backrest spring to create that table spot to support the padding during installation. Lots of other tips in the video as well.
fordt
- First Name: Rob
I believe I’ve looked at that, referring to the burlap first layer! I think Classtique mentions that as well….in order for the batting to not fall down into the springs.
Thanks!
Thanks!
