1915 hood former step bolts
Topic author - Posts: 366
- First Name: Bill
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1916 Model T Touring
- Board Member Since: 2006
Does anyone know where to find the wide head step bolts that were used on the 1915/16 T’s? They are 2 5/8” long, 1/4” wide with a large, flat 1” head.
- Last Name: Strange
- Board Member Since: 2013
Re: 1915 hood former step bolts
Maybe here? https://blacksmithbolt.com/collections/step-bolts
Or, check with Lang's or Bob Bergstadt, seller modelt2001 on eBay.
- First Name: Ronald
- Last Name: Dupree
Check at your local hardware store for "Elevator bolts". Our local Menards carries them, others probably do as well.
Ron Dupree
- First Name: Craig
- Last Name: Luton
- * REQUIRED* Type and Year of Model Ts owned: 1914 Ford Runabout; 1915 Ford Touring; 1936 Ford Pick-up
Take a chunk of steel bar, chuck it in a lathe and turn it to the size you need and mill the flats. That is what I do for all my antique cars. Elevator bolts are flat on the top and that is not what you are looking for. Step bolts have a smaller head then what you need..... Craig
I braze a washer under the head of a normal hardware shop carriage bolt and machine it to suit. This works for all sizes.
- First Name: Craig
- Last Name: Luton
That is a good method, I have done that also.
- First Name: Keith
- Last Name: Townsend
They are step bolts, not elevator bolts. Try local Ace hardware. File the markings off the head and use muriatic acid to remove the cadmium plating before you paint them.
Older post on those hood former bolts. The shank is 5/16” dia. Head is approx 1” with low dome, not flat.
https://www.mtfca.com/phpBB3/viewtopic.php?f=2&t=29167
- First Name: Tom
- Last Name: Rootlieb
If you need a couple let me know. I have 5/16 X 1 1/2 and 5/16 X 2 1/2.
- First Name: ROBERT
- Last Name: BERGSTADT
Here you go NOS Original Bob
eBay item number:156171800990
