WTB Fun projects brake light switch
Tmooreheadf
Last Name: Moorehead
Post by Tmooreheadf » Sat Jul 06, 2024 8:18 pm
Anyone have a Fun Projects brake light assembly they'd like to sell? PM me if you have one you may not need anymore!
Re: WTB Fun projects brake light switch
Post by Steve Jelf » Sun Jul 07, 2024 12:21 am
I made mine. the store-bought part was Ace Hardware's least expensive pushbutton switch. The rest was all stuff I had on hand. I doubt the total cost was over ten bucks. It ain't rocket surgery.
Moxie26
Last Name: Jablonski
Post by Moxie26 » Wed Jul 10, 2024 3:23 pm
Hey Tom... Any luck in obtaining that brake switch?... I'm sorry I don't have one for sale but I do have one on my 26. And it works just fine. ..... Too bad, the one who bought Mr. Regan's business is not producing this switch anymore .
Post by Steve Jelf » Wed Jul 10, 2024 5:17 pm
Not much action here. Hasn't anybody else made their own? If I could do it, just about anybody can.
https://www.youtube.com/watch?v=lH85w4Yqhi4
Post by John kuehn » Wed Jul 10, 2024 5:25 pm
Here’s a super simple brake light switch. As Steve says it ain’t rocket science. This is Lang’s version. https://www.modeltford.com/item/3158RS.aspx https://www.modeltford.com/item/3158RS.aspx
Post by Steve Jelf » Wed Jul 10, 2024 5:39 pm
I gather Lang's switch is pushbutton. That is simple and clever, and I bet it lasts a long time.
Last Name: Wrenn
Post by TWrenn » Wed Jul 10, 2024 6:04 pm
I had one of those on my former '15.
While it worked it was horribly difficult to keep adjusted so as to just be able to tap the brake pedal to engage the light and NOT the brake. Fun Projects is excellent at being able to achieve that. I have the FP switch on both my current T's.
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Wed Jul 10, 2024 6:53 pm
I have a Regan design brake switch, which works well. It involves a lever to actuate a push switch. If I was to make a brake switch, I would consider a pull type switch in order to eliminate the lever. Normally off, and on when pulled, type switches are hard to find, but are available.
Art Mirtes
aDave
First Name: David
Last Name: Dufault
Post by aDave » Wed Jul 10, 2024 8:31 pm
Tom,
Is this what you are looking for?
Dave
Gracie'sDad
Last Name: Dow
Post by Gracie'sDad » Thu Jul 11, 2024 10:41 am
I have a Lang's # 3158RS brake light switch I used for 6 months before I converted to disk brakes which had a pressure type switch included. PM me and for $20 I'd mail it to you, lower 48 only.
Post by Original Smith » Thu Jul 11, 2024 11:19 am
Why doesn't someone remake those crappy Chinese switches and put a workable unit inside?
Post by RajoRacer » Thu Jul 11, 2024 11:32 am
Snyder's catalog currently has the Ford style Bendix can switches available the say "Made in the USA" Larry - I installed one on a friend's T and it was O.K.
Tmooreheadf
Post by Tmooreheadf » Thu Jul 11, 2024 8:22 pm
I have found my switch. Thanks for all of the comments!
Tom
Last Name: Wrenn
Post by TWrenn » Fri Jul 12, 2024 8:23 am
Tom
You mean you actually found a Fun Projects switch? I sure hope so, cause they're the best! If you did, wonder where ya
got it from? I wouldn't mind one just to have for spare parts or if I ever get yet another T!!
AdminJeff
Last Name: Stevenson
* REQUIRED* Type and Year of Model Ts owned: 1921 Touring
Post by AdminJeff » Mon Jul 15, 2024 12:59 am
Show me a pic of the FP switch...
Assistant WebSite Admin
www.modeltregulators.com
www.modeltstarters.com
Post by RajoRacer » Mon Jul 15, 2024 11:01 am
I believe Larry was referring to the copy of the clamp-on style for the Bendix can - Snyder's now carries USA made ones - way better than the previous ones.
Tbird
Last Name: Bird
Post by Tbird » Mon Jul 15, 2024 9:17 pm
Here’s a FP switch new that has not been installed
The switch is a 60 amp push button w/hex mounting nut and a rubber bulb seal ring.
Before I found this one I contacted Bird Haven several times, they had everything except the 60 amp push button switch. Supply issues….
