FS RACING INTAKE MANIFOLD (SOLD)
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Wed Jul 31, 2024 4:09 pm
I have two RAJO high volume intake manifolds available for purchase. These were designed for use on a boredout Model T flathead engine block. They are similar in design to the Winfield 2 up 2 down intake manifold. Ports are 1 3/8". Carburetor side throat diameter is 1 5/8". Bolt flange is Winfield Model M201 B size. Price is $200 each plus domestic shipping. Mark Chaffin (951) 805-0928
themadmodelt
First Name: Brian
Last Name: Sullivan
* REQUIRED* Type and Year of Model Ts owned: 1922
Re: FS RACING INTAKE MANIFOLD
Post by themadmodelt » Wed Jul 31, 2024 4:35 pm
VM/txt sent
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Wed Jul 31, 2024 11:53 pm
One sold to Dave. Thank you
Ralph F
First Name: Ralph
Last Name: Fitz-Gerald
Post by Ralph F » Thu Aug 01, 2024 7:56 am
Mark would this manifold fit a roof liberty eight over head.
Fitz
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Aug 02, 2024 1:19 am
Fitz
Both the single intake and the dual intake port Roof heads have vertical mounting flange holes. No doubt port spacing is near identical tho as the ports are centered about the cylinder pairs
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Fri Aug 02, 2024 8:57 am
Thank you Kevin for the info. :)
Ralph F
First Name: Ralph
Post by Ralph F » Fri Aug 02, 2024 9:33 am
Thanks Kevin always good to get good information.
Fitz
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Fri Aug 09, 2024 6:43 pm
One remaining. This will be the last for use with a Ford Flathead engine. :)
blauvelt
First Name: Douglas
Last Name: Ogden
Post by blauvelt » Tue Aug 13, 2024 12:48 pm
Will take the last one.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Tue Aug 13, 2024 2:52 pm
Sold to Doug. Thank you. :)
