Today’s project
- First Name: Randall
- Last Name: Strickland
Re: Today’s project
I like your depth gauge! I have a couple I need to do
- First Name: Dennis
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Re: Today’s project
I am trying to figure out what you are repairing.
Topic author - Posts: 263
- First Name: DEAN
- Last Name: YODER
- * REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
Re: Today’s project
Wish bone ball socket.
- First Name: Adam
- Last Name: Doleshal
Re: Today’s project
Turn the speed way down. Maybe 200 rpm. Then it will look like this:
- Last Name: Nunn
Re: Today’s project
Can you explain how you built up the material around the socket? Weld, braze, other method? I need to find a way to fix this.
- Last Name: Pawlowski
- * REQUIRED* Type and Year of Model Ts owned: 1925 Roadster
Re: Today’s project
Hello all,
My question is what do you use to form the socket?
Is this something that can be done in a drill press?
- First Name: Bob
- Last Name: Shirley
Re: Today’s project
I’m with John, please post a picture of your cutter, the model number and where to purchase. Thanks
- Last Name: Hatch
Re: Today’s project
Tool is called ball end mill.
- Last Name: Gould
Re: Today’s project
An 1 1/4 " ball mill requires a lot of pressure to cut weld. I can't see how a drill press would work. I did the same thing using a tig welder and silicon carbide with a 1910 pan and the pressure warped the pan on a mill. I like the idea of brazing the hole. Not so tough to cut
- First Name: DEAN
- Last Name: YODER
Re: Today’s project
Richard, You need to drill a 3/8 inch pilot hole before you use the end mill. Doesn’t require as much pressure.
