Schraeder valve number
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Wed Sep 25, 2024 1:05 pm
What Schraeder valve stems would be used on the ‘26-‘27 wire wheel tubes?
Last Name: Humble
Board Member Since: 2006
Re: Schraeder valve number
Post by Humblej » Wed Sep 25, 2024 1:18 pm
I would go with something around 2" long.
TMiller6
First Name: Thomas
Last Name: Miller
* REQUIRED* Type and Year of Model Ts owned: 16, 24, 26 Touring - 26 Roadster and Fordor
Post by TMiller6 » Wed Sep 25, 2024 1:44 pm
In case you want to buy new, the valve stems for ‘28-9 fModel A fit perfectly.
Tom Miller
Post by Steve Jelf » Wed Sep 25, 2024 2:58 pm
The correct stems for Model T before 1926 are Schrader #777. I haven't studied 26-27, but I would guess they are the same. I'm not good enough with Google to know the actual diameter of Snyder's 28-29 Model A stems. The major thread size for a #724 stem is 0.482-26. For a #777 stem, it is 0.406-28. I have not found the 777 size used on ANY modern tube. All the modern metal stem tubes I've seen have the wider #724 size. All the repop covers I've seen are made to fit #724, not the narrower #777. Original covers are easier to find in the #724 size, so the stems I use are #724 and #725 (same diameter as #724 but a little longer).
https://dauntlessgeezer.com/DG110.html
modeltspaz
Last Name: Spaziano
Post by modeltspaz » Wed Sep 25, 2024 4:04 pm
To answer the O.P.s question: Schrader 888.
This is the correct valve stem for a Ford welded wire wheel.
Post by Original Smith » Mon Sep 30, 2024 11:41 am
I use 888's in all of my cars. A little lighter than a 777. Keep in mind, Dill and Bridgeport also made these, but have different numbers. The TR number is the same.
