Switch repair
Topic author - Posts: 71
- First Name: Gary
- Last Name: Gregory
- * REQUIRED* Type and Year of Model Ts owned: 1927 Model T Roadster
Switch repair
What do you guys use to attach the switch onto the switch plate ? This one had small rusty screws which I know isn't correct. Came off my 27 Roadster.
Re: Switch repair
Exact copy of the original rivets I have.
- First Name: Gary
Re: Switch repair
RajoRacer where could I get a set ?
Re: Switch repair
I don't think the original rivet will work, the holes have been drilled out to larger size for the screws. As I recall that rivet is about 1/8" approx (may be a bit smaller then that).
Re: Switch repair
It depends on how much of a purist you are. I would discard the plate you have, and find another. The appearance of the rivets for that switch plate are important, and it wouldn't look right to have screws or oversize rivets.
Re: Switch repair
Send me an email - I'll throw a pair in an envelope. These were machined by Otis Clinton - Larry knew him well !
