What is this ford wrench for?
Topic author - Posts: 40
- Last Name: Grabowski
- * REQUIRED* Type and Year of Model Ts owned: 1924 Fordor
I’m wondering what this ford wrench is for? Has Ford script with U.S.A. on one side and the letter M on the other.
- First Name: Dennis
- Last Name: Seth
Re: What is this ford wrench for?
OK, Everyone knows that I'm the forums resident smart a$$ so I'll answer...
"What is this wrench used for?"
It's used to tighten Nuts on bolts!
- Last Name: Barclay
- * REQUIRED* Type and Year of Model Ts owned: 1920 coupe
Sorry I can't help it. If you turn it around you can use it to loosen bolts and nuts also.
It would be Ford Model A up including tractors. Not T and not band adjusting wrench. The openings are ether 1/2-9/16 or 9/16-5/8.
Thank you Mark, much appreciated.
