Pretty sure it's not Bosch.
Anyone Recognize this Aftermarket Timing Cover?
Rodger Erickson
Topic author - Posts: 481
- First Name: Rodger
- Last Name: Erickson
- * REQUIRED* Type and Year of Model Ts owned: 1920 Speedster
AndyClary
- First Name: Andrew
- Last Name: Clary
Re: Anyone Recognize this Aftermarket Timing Cover?
I have one on my coupe, maybe an early Bosch plate without the thrust button? Works with the Bosch gears.
Andy
Andy
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Nope- Andy gets no cigar this time.......... The plate is Atwater Kent. Gears are available from the vendors. There are two styles of AK plates in addition to the more common clip on variety. Note this one has a lower support above where the gear mounts. The other style has no lower support more like Bosch, BUT, Bosch gears will not work with either style. Center distance is totally different.
AndyClary
- Last Name: Clary
My bubble is burst. I guess that’s what happens when you assume.
Andy
Andy
DustySpokes
- First Name: Edmund
- Last Name: Niedzielski
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1922 Mercury Bodied Speedster, 1926-27 Roadsters /Tourings
This is identical to the Factory advertisement in the July 1921 issue of Ford Owner and Dealer, see page 26. . It is a type CA , which had automatic advance. -Dusty
