Model T magneto Regulator ?
Topic author - Posts: 179
- First Name: Mike
- Last Name: Sleep
- * REQUIRED* Type and Year of Model Ts owned: I have 22, 24, 26 coupe, 25 pickup, 23 roadster, 27 touring and 26 Fordson.
Removed this from a car I purchased. Is this used to charge a battery, run lights, or? Was going to throw it on a table at a swap meet, but not sure what it does or if it has any value.
Re: Model T magneto Regulator ?
Magneto powered battery charger, I believe.
- First Name: Mike
- Last Name: Sleep
For an early non-starter cars that use a “helper” battery to ignite coils. This would charge that battery?
- Last Name: Maxson
The website is dead, is True-fire out of business?
Mike
Beware.
It will charge a battery but when it is fully charged the internal
circuitry will render the magneto useless for driving because it cuts off 1/2 of the
magneto waveform connected to the coils.
Ron Patterson
Beware.
Ron Patterson
- Last Name: C
Even when wired parallel off the magneto?Ron Patterson wrote: ↑Thu Mar 13, 2025 10:36 amMike
Beware.
Ron Patterson
Bridge rectifier?
- Last Name: van Ekeren
It is a shame that they are not made any more, I use a 6v bittner charger and a E timer so I have good lights on a 16 for many years, a much better set up than the diode and globe on the mag.
