Going to re Babbitt the fourth main soon.
When it goes time to line bore to size , I will be using my lathe, which surface on the ball do I use to indicate off ?
Re Babbitting a fourth main
Re: Re Babbitting a fourth main
The machined edge under the mounting flange. This is where it contacts/centers itself in the motor.
- Last Name: Hatch
Find the old thread by Herm about transmission rebuilding. He shows how to .
Where the flange meets the ball part, there is a machined surface, that is where you center off.
Topic author - Posts: 90
- Last Name: Eddie
- * REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1926 Touring, 1931 Plymouth PA, 1952 Hudson Hornet
Got it thanks
- Last Name: van Ekeren
I made use of a T wheel hub flange plate as a face plate for the lathe years ago, still using it, centre the ball cap at the machined surface near the ball cap flange.
