1913 KW Coilboxes
1913 KW Coilboxes
Post by Original Smith » Sat Apr 19, 2025 1:10 pm
Ford only used this coil box for one year. They used mica pieces below the common grounding strip on the bottom to insulate the ground from the mag and battery wires. These mica pieces appear to be about 1 1/8" to 1 1/4" square, and about .030 thick. Does anyone know if mica is available like that?
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: 1913 KW Coilboxes
Post by Dan McEachern » Sat Apr 19, 2025 1:20 pm
McMaster-Carr carries it in various thicknesses, but it's not cheap!! Might try an electric motor shop.........
Moxie26
Last Name: Jablonski
Post by Moxie26 » Sat Apr 19, 2025 2:48 pm
Larry... Please post pictures of your coil box wiring
Post by TRDxB2 » Sat Apr 19, 2025 9:40 pm
Looks like you could make your own....
YouTube shows cutting with https://www.youtube.com/watch?v=1aGzz_G07KY
Shears in the video - inexpensive
https://beadaholique.com/search?type=product&q=shears
https://www.google.com/search?q=mica+sq ... 1.33#pvs=0
