Is this a Good Idea? Oil Screen Question
Topic author - Posts: 504
- First Name: Daniel
- Last Name: Snell
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
- Board Member Since: 2014
I recently pulled of the inspection plate on the transmission cover and found this magnet in the accessory oil screen. I thought those old timers on the forum might chime in on whether this is a good idea? It seems to me that it is as some unwanted crud was attached to the magnet, but maybe there is some unforeseen negative consequences to this? Your thoughts, Thanks. [/size][/b]
- Last Name: Humble
Re: Is this a Good Idea? Oil Screen Question
I have a magnet in my screen.
- Last Name: Hanlon
I advise securing it with some stainless wire.
- Last Name: van Ekeren
The screen kits come with a magnet.
- First Name: Gene
- Last Name: Carrothers
Great idea and we've used it many years. It's not going anywhere and you can easily remove it to clean.
1912 Torpedo Roadster
- First Name: Henry
- Last Name: Lee
Mounting it on the outside unless you wish to become a member of the Hank Lee Magnet Eater Club. They can migrate, crumble to pieces, and lose strength through heat cycles. Others have had issues, my engine/transmission with 1000 miles on it, totally destroyed. $6,500.0 flushed down the toilet.
Just My Two Cents with New Sense!
Hank in Tin-A-See
Hank in Tin-A-See
It's one of the best improvement for a Model T. I have them in all my cars. There are so many particles on the magnet each time I take the cover off. I hate to think of them staying with the oil.
- First Name: Henry
- Last Name: Lee
Vibration, heat cycles, make a rare earth magnet eventually self destruct. Mounting a magnet on the outside works just as good without spending a war chest in repairs. I have said my peace, you have been warned! How many of you have replaced your electric motors in your power windows in your cars? Rare earth magnets cracking and breaking up!
All the Best,
Hank
All the Best,
Hank
- Last Name: Juhl
Anyone else have an experience like Hank? I safety wire my magnet in place...don't know if that helps or not.
- Last Name: Noonan
- * REQUIRED* Type and Year of Model Ts owned: 1925 Runabout
Never heard of one crumbling while just sitting in the tray, but the idea of one migrating into the engine is scary enough to warrant using a little safety wire to be on the safe side.
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again.
- Last Name: Osterman
The one I have in my screen is incredibly strong .... actually difficult to remove. Don’t think it’s going anywhere.
- Last Name: Snell
Hank, When you refer to "mounting the magnet on the outside", the outside of what the transmission cover, case or screen?
- First Name: Roger
- Last Name: Harmon
I was wondering that too. Maybe on the door, so you can remove and clean it?surveyking wrote: ↑Thu Jun 27, 2019 10:33 pmHank, When you refer to "mounting the magnet on the outside", the outside of what the transmission cover, case or screen?
