26-27 running board brackets
				dunoon
Topic author - Posts: 133
 - Last Name: Davis
 - * REQUIRED* Type and Year of Model Ts owned: 1926 coupe
My running board brackets seemed to be bent.  Should they be parallel to the floor.  Also, what can I use as a reference for the brackets fore and aft.  Im planning to bend them with a piece of pipe.  Anybody have a better idea.  Thanks
				Ken Buhler
 - First Name: Ken
 - Last Name: Buhler
 - Board Member Since: 2012
Re: 26-27 running board brackets
Google: model t frame dimensions mtfca    and you can print it.
Ken
									Ken
Work honestly
Stay true to your word
Get the job done right
 - Last Name: Humble
Should be parallel to floor.
				jab35
 - Last Name: Bartsch
Make sure the frame of the car is 'parallel' with the plane of the floor before you adjust brackets.  I have seen front RB supports on the '26-'27's reinforced with a piece of square tubing bolted across the underside of the of the bracket full width of the car.  I think they used 1" square tubing and running board bolts ~2 inches longer than stock on the front bracket.  Doesn't work for rear b/c driveshaft interferes.  Not stock, but an effective solution to strengthening the structure. jb
This is helpful drawing, while not Ford work, dimensions are very suitable for stock '26-'27 frame.
The best way is always the simplest. The attics of the world are cluttered up with complicated failures.     Henry Ford
