Broken Band Washer
John_Aldrich
Last Name: Aldrich
* REQUIRED* Type and Year of Model Ts owned: 1915, 1923. 1927
Broken Band Washer
Post by John_Aldrich » Thu Jun 27, 2019 7:35 pm
Retired like I am I enjoy spending time working on my T's as well as a Model A and more recently a 1940 Cadillac LaSalle.
My brake pedal was a little low on my stock 1915 Model T so since I have a wooden band on there I thought that was a little odd. True enough they have been in there for 6 or 7 years but I broke them in softly and they have given me years of trouble free operation.
Imagine my surprise when I discovered the washer in there "cattywampuss".
And now I know why!
Anyone every seen this before? (I'd be surprised if I were the first one to see this)
John Aldrich
Typical Model T Addict
Re: Broken Band Washer
Post by Original Smith » Fri Jun 28, 2019 10:22 am
Never have seen that in 59 years! Replace it with another, and you'll be set.
Post by Norman Kling » Fri Jun 28, 2019 10:43 am
Every time you depress the brake pedal, you put a bit of strain on that washer. Finally it broke. You are very fortunate it didn't fall into the transmission. If it had, you might have had a big disaster. Just replace the washer and make your normal adjustment.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Fri Jun 28, 2019 11:49 am
It’s a recently made modern repro washer and was probably a bad stamping that was just about broke through from the day it was made. I can see it from a mile away. The repros seem to be made by more than one vendor. Look at them close before you install a repro.
Post by John kuehn » Fri Jun 28, 2019 1:49 pm
I have been to a lot of swap meets over the years and farm auctions and have never seen a worn out, bent or broken bandwasher In the junk box’s I have looked at. Seen a few rusty ones used as washers on old farm equipment but never a broken one. That one is probably a reproduction. Learn something new everyday I guess.
