Need “one” Cast Iron Sunderlin Sunderland type Rocky Mnt Brake Drum
NorthSouth
Last Name: California
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1926 Pick Up
Post by NorthSouth » Fri Jul 18, 2025 3:14 pm
Would anyone have “one” cast iron Rocky Mountain Break Drum. I need to match the one pictured below.
Thanks,
Steve
Los Angeles
Original & Sunderlin (sp) Rocky's had 2 drums cast as one - that's how mine are. -Ed Archer
Sarikatime
Last Name: Seress
Re: Need “one” Cast Iron Rocky Mnt Brake Drum
Post by Sarikatime » Fri Jul 18, 2025 4:07 pm
Steve, Those are, I believe, two different brake drums stuck together. Call the Rocky Mountain brake drum manufacturers, phone and information available in the Vintage Ford magazin advertisement. Also, maybe call Dave at Chaffins garage, he got me new linings when my brakes got hot and caught on fire.
Post by RajoRacer » Fri Jul 18, 2025 4:51 pm
Original & Sunderlin (sp) Rocky's had 2 drums cast as one - that's how mine are !
NorthSouth
Post by NorthSouth » Sun Jul 20, 2025 3:54 pm
Back to the Top
NorthSouth
Re: Need “one” Cast Iron Sunderlin type Rocky Mnt Brake Drum
Post by NorthSouth » Fri Aug 01, 2025 2:10 pm
I am still looking for one of these drums.
NorthSouth
Post by NorthSouth » Wed Aug 06, 2025 4:08 pm
Would anyone have an alternative idea on how to get break drums that will work with and original set of large drum Rocky Mountain Brakes?
First Name: john
Last Name: karvaly
Post by speedytinc » Wed Aug 06, 2025 4:11 pm
Check with the current mfg. Get dimensions. I believe the drums are the same size, just not the preferred cast iron.
Buy a pair.
Craig Leach
First Name: craig
Last Name: leach
Post by Craig Leach » Thu Aug 07, 2025 1:43 am
Hi Steve,
The RM drums are advertised as 11 3/4" and the one in your pic looks to be 12" ( the larger drum) I have no idea the width of the cast drums.
Have you giver any thought to having a metal fab shop roll a ring the correct width of 1/8" or 3/16" cold or hot rolled steel that can be heated to
fit over a RM drum so it shrinks to fit tight then welded & machined to the needed specs to match? At least you would not have to worry that it
was worn out?
Craig
NorthSouth
Post by NorthSouth » Thu Aug 14, 2025 1:35 pm
Maybe the manufacturer’s name is spelled “Sunderland”. I still need one of these break drums to match the one pictured above.
NorthSouth
Re: Need “one” Cast Iron Sunderlin Sunderland type Rocky Mnt Brake Drum
Post by NorthSouth » Sun Aug 17, 2025 8:52 pm
I need one of these.
Post by Original Smith » Mon Aug 18, 2025 10:49 am
Sunderlin is correct.
NorthSouth
Post by NorthSouth » Thu Aug 21, 2025 12:27 am
I am giving up finding this break drum.
Having two new ones cast.
