Could someone please tell what size wrench is used on the exhaust pipe pack nut ?
Thank you
Johnr
exhaust pack nut dimension
Re: exhaust pack nut dimension
Appropriately 2 1/16” - 2 1/8” opening on Ford pack nut wrench.
- First Name: Vernon
- Last Name: Worley
https://www.modeltford.com/item/3061W.aspx
https://www.snydersantiqueauto.com/prod ... &cat=41910
I made my own. If I can find the math on it I will share.
Vern (Vieux Carre)
An 18" Bahco [crescent] adjustable wrench works fine for me.
- First Name: Edward
- Last Name: Baudoux
The Ford issued exhaust nut wrench measures 2.043".
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
- First Name: Derek
- Last Name: Dudgeon
- Board Member Since: 2022
If you have a reproduction pack nut, the factory wrench may not fit. I've run across several of the reproductions that were at least a 1/16" oversize, the ones that are more simply machined without bevelled corners tend to be the worst.
The big shifter fits all variations.
