My Big Ford Disc brakes
Wolffydmc16
First Name: Clint
Last Name: W
* REQUIRED* Type and Year of Model Ts owned: 1921 Touring
Post by Wolffydmc16 » Mon Aug 18, 2025 12:31 am
Made my own disc brake swap to my knowledge its not been done before with these parts.
This conversion is NOT BOLT ON as it required welding and some basic fabrication. Im not making more of these. I have over 2500 miles of use on them including decending a 15% grade - no issues! 330mm rotors are plenty big but don't stick out too obvious behind the wheels.
2012 Ford fusion rear calipers (2nd gen Fusion/Mazda 6) and parking brake cables
2012 Ford Taurus rear rotors ( 3rd gen Taurus, base model non vented)
Willwood universal 7/8" master cylinder
I selected these rotor as they fit perfectly over small drum axle backing plates. No original T parking brake shoes used.
The calipers have a fantastic cable operated parking brake mechanism that is just as powerful as the hydraulics.
The cables are too long to operate the same side wheel as the T parking brake cross bar but are just the right length to cross to the other side. Made some brackets to attach the cables to the frame and to attach to the brake equalizer bar, able to Pivot when the brake handle is forward.
Calipers are mounted to the radius rods with some welded on 1/4" steel tabs.
Brake rotors had a 5x108mm bolt pattern and we need it to be 6x 5" so they were welded up and re drilled for the 3/8" bolts and are sandwiched between the axle flange and billet adapters to fit the early Model A wheels instead of stock rear drums. Would it fit with stock wood wheels? Probably, never tried.
Calipers did need to some trimming to clear the spokes of the A wheels, not a big issue.
Master cylinder was mounted like the Willwood disc kit does. I made a 3/16" bracket on the output flange. I welded a tab on the brake pedal and a double shear clevis connects it to the master, 6:1 mechanical ratio.
Thanks for looking!
1921Touring "Tootsie T" my first Model T
Last Name: Hatch
Re: My Big Ford Disc brakes
Post by Dan Hatch » Mon Aug 18, 2025 5:04 am
Question: What is this circled in yellow and what does it do.
Thanks Dan
Post by Allan » Mon Aug 18, 2025 7:10 am
It looks to me to be a lever action hydraulic shock absorber typically used on English cars like Morris Minors, Austin Healy Sprites etc. Does it help dampen axle tramp?
Will
First Name: Will
Last Name: Copeland
* REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
Post by Will » Mon Aug 18, 2025 9:12 am
Amazing, I do love when someone posts an ingenious fabrication that not only works but is mostly cosmetically invisible to other than those who would know. I wish I had the brains to be able to dream up something like this and make it a reality.
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
Post by TXGOAT2 » Mon Aug 18, 2025 9:32 am
Very nice installation, and more brake than the tires can fully utilize. The double acting shocks will make a huge improvement in ride and handling, and will further improve braking.
Wolffydmc16
First Name: Clint
Last Name: W
Post by Wolffydmc16 » Mon Aug 18, 2025 5:23 pm
Thanks Dan
Yes I also installed a set of Armstrong lever shocks on all corners, really stops me from bouncing out of the seat
kelly mt
Last Name: Kelly
Post by kelly mt » Mon Aug 18, 2025 8:21 pm
Nice work.
GregC
First Name: Greg
Last Name: Cunningham
* REQUIRED* Type and Year of Model Ts owned: A single SCAT crankshaft
Post by GregC » Tue Aug 19, 2025 8:12 pm
Very nice work!! Any plans to add discs to the front axle???
Wolffydmc16
First Name: Clint
Last Name: W
Post by Wolffydmc16 » Wed Aug 20, 2025 1:02 am
None at the moment, I'm trying to just enjoy this car as is while I can and concentrate on picking up a local Speedster that I have more creative plans for, that will be getting four wheel brakes.
GregC
First Name: Greg
Post by GregC » Wed Aug 20, 2025 9:29 am
Very cool. Will be watching to see what you do with it!!
mbowen
First Name: Miles
Last Name: Bowen
Post by mbowen » Wed Aug 20, 2025 7:07 pm
I don’t know for sure, but have read elsewhere in these forums that the Model T front axle structure isn’t adequate to support braking forces.
Miles
1924 Touring “Bonnie”
1925 Express Wagon “Clyde”
