Driveshaft bushing
Topic author - Posts: 146
- First Name: Will
- Last Name: Copeland
- * REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
Driveshaft bushing
How do I remove the driveshaft bushing?
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
- Last Name: Juhl
Re: Driveshaft bushing
They make a puller for that purpose or you can try to carefully drive it out. I tried to drive it with my drive shaft (which I was replacing) and sheared off some of the rivet heads holding the ball on. I was able to replace them but it made what looked like a simple job much more complicated. Langs sells a puller for $27 - maybe someone on the forum will read this and offer to loan you one. I would but I don't have one.
I believe I built mine from a tinkering tips manual. It consists of a 1/2" pipe cap machined a bit to fit into the base of the bushing & 4 wide notches to clear the rivets. The cap is screwed onto a pipe one foot longer than the drive shaft. Carefully align the cap to clear the rivets & hit the end of the pipe. Very effective. Be sure to clear the rivets. If you shear those rivets, you made a whole lot of extra work to fix, to the point of being easier to start over with a second D.S. tube.
The pipe cap machining looks like the business end of that Langs tool.
- First Name: Ed
- Last Name: Fuller
- Board Member Since: 2012
I’ve used this several times with success. I took a thick washer and ground down the sides to clear the rivets inside of the tube. The washer fit over the threaded end of an old steering shaft and was just the right length to be able to knock out the old bushing. You could also use a length of pipe instead of a steering shaft.
DIY tool https://modeltfordfix.com/rebuilding-the-drive-shaft/
The tool is made from 1/2″ galvanized pipe, a piece that is 60 inches (5 feet) long. 1/2″ water pipe measures .840″ on its outside diameter, the size designation refers to the inside diameter. The cap measures a little less than 1 inch outside diameter at its smallest dimension – perfect for our tool.
The notches need to be deep enough & wide enough to clear the rivets. Insert from the spool end
- Attachments
- Drive-shaft-bushing-remover-tools.jpg (36.22 KiB) Viewed 402 times
Doesn't Glen Chaffin's Axle book show the easy way? I seem to remember seeing it in one of those MTFCA books. i should have shot a video when I did it.
Yea, thats the tool.TRDxB2 wrote: ↑Sun Aug 24, 2025 2:42 pmDIY tool https://modeltfordfix.com/rebuilding-the-drive-shaft/
Good article.
The only thing I would add is to lap the pinion gear to the D.S. taper. Makes for 100% taper contact. Wont get loose or turn.
- Last Name: Hatch
You also need the tool for reaming the bushing to fit the driveshaft.
Mine is just like Frank's. Variations in the pipe cap shapes and galvanised coating may mean you have to run a bit off the outside Of the cap, but this just makes the register on the raised collar that much cleaner and better.
- First Name: Will
Thanks everyone for your help, Being this is my first time removing the bushing I'm going to wait until I can get a friend to walk me through it. I could be only one sheered off rivet for a major from job.
- First Name: Kent
- Last Name: Palazzo
I used this tool when I did mine this last winter. It works great! but I also added a big flat washer under the nut and smeared grease on both surfaces and on the threads. Turns so much easier and popped the bushing out effortlessly. You also want to get the installer and ream tool to face off the new bushing when putting the new universal on. Don't forget to drill the grease hole in your new bushing before installing the driveshaft.Oldav8tor wrote: ↑Sun Aug 24, 2025 10:55 amThey make a puller for that purpose or you can try to carefully drive it out. I tried to drive it with my drive shaft (which I was replacing) and sheared off some of the rivet heads holding the ball on. I was able to replace them but it made what looked like a simple job much more complicated. Langs sells a puller for $27 - maybe someone on the forum will read this and offer to loan you one. I would but I don't have one.
- First Name: DAN
- Last Name: MCEACHERN
A 3/4" pipe tap is the perfect size to screw into the old driveshaft bushing. With the tap in place, its an easy job to use any stiff rod to drive the tap and old bushing out of the driveshaft tube- no special tools required.
What he said^^^Dan McEachern wrote: ↑Tue Aug 26, 2025 4:11 pmA 3/4" pipe tap is the perfect size to screw into the old driveshaft bushing. With the tap in place, its an easy job to use any stiff rod to drive the tap and old bushing out of the driveshaft tube- no special tools required.
- First Name: Rich
- Last Name: Bingham
I’ve had good results using a tap to remove “blind” or flanged bushings. Perhaps Frank’s shop-made tool would be economical for some. The cheapest 3/4” pipe tap listed in McMaster-Carr is $97.87. YMMVDan McEachern wrote: ↑Tue Aug 26, 2025 4:11 pmA 3/4" pipe tap is the perfect size to screw into the old driveshaft bushing . . .
Get a horse !
The use of a tap is easy, use a tap to remove spindle bushings too.
On my removals, I have an old steering post, the end is tapered, no fear of hitting torque tube rivets. To the threaded end added a std. bushing driver, from a China made set of bushing drivers. Nut fastened to the pitman arm threads.
A whack with my favorite Model T tool takes it out!
The cheapest 3/4" tap on eBay is $8.98, with free shipping.Rich P. Bingham wrote: ↑Tue Aug 26, 2025 6:57 pmI’ve had good results using a tap to remove “blind” or flanged bushings. Perhaps Frank’s shop-made tool would be economical for some. The cheapest 3/4” pipe tap listed in McMaster-Carr is $97.87. YMMVDan McEachern wrote: ↑Tue Aug 26, 2025 4:11 pmA 3/4" pipe tap is the perfect size to screw into the old driveshaft bushing . . .
