New Blockley BS?
Topic author - Posts: 5192
- Last Name: Hatch
New Blockley BS?
Just got an email from UPS customs wanting a nhtsa hs-7 form for my 1 tire and 4 tubes. What the F now? Says if I don’t get it back asap going to start charging me storage. Just giving yous guys a heads up. Dan
- Last Name: Juhl
Re: New Blockley BS?
Tariffs.....used to be you could avoid them if total less than $800 - that loophole has been cancelled.
- First Name: Kevin
- Last Name: Pharis
Yeah, a friend told me just yesterday that he had to pay UPS $190 in duties to import a set of tubes from Blockley. No mention of customs forms, but we have discussed the inconsistency of government enforcement on this topic before…
Not sure what's going on but a HS-7 form isn't about tariffs it appears to be related to Federal Safety standards. Are Blocklely Tires DOT rated? Maybe that's what its about. It also could be that UPS made a mistake i their thinking. OR need to identify the proper tire description for a tariff. Motorcycle tires might be tariff free
§ 591.5 Declarations required for
importation.
(j)(1) The vehicle or equipment item does not conform with all applicable Federal motor vehicle safety and bumper standards, but is being imported
solely for the purpose of:
(i) Research;
(ii) Investigations;
(iii) Show or display;
(iv) Demonstrations or training; or
(v) Competitive racing event
This is the Hs7 Declaration see check box 7
https://www.nhtsa.gov/sites/nhtsa.gov/f ... ecured.pdf
- First Name: Steven
- Last Name: White
Seen it before more stupid gov regs that serve no purpose .
- First Name: Will
- Last Name: Copeland
- * REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
Dan, keep us posted on this, I was getting ready to order some tires. I just took a look at that form, I wound not know how fill that out!. I will hold off until its figured out. I wonder how this will effect other things.
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
Did some more checking and see that Blockley tires are DOT certified. Don't know about the inner tubes, but they need DOT certification if for highway use. So, you'll need to ask UPS, "specifically", why the declaration is required because you can't fill out the hs-7 form out without that knowledge
