Wanted - brass sediment bulb and brass (DB) steering wheel spyder
Topic author - Posts: 190
- First Name: Craig
- Last Name: Luton
- * REQUIRED* Type and Year of Model Ts owned: 1914 Ford Runabout; 1915 Ford Touring; 1936 Ford Pick-up
Looking for a good brass sediment bulb that will not leak. Also looking for a brass (DB) steering wheel spyder. Contact me through the e-mail link below.
Thank you, Craig
Thank you, Craig
Re: Wanted - brass sediment bulb and brass (DB) steering wheel spyder
There are different types of brass sediment bulbs. Stating the year of car might get better responses.
- Last Name: Hatch
Somebody has a bucket full on them as of Saturday.
- First Name: Craig
- Last Name: Luton
Thanks, The brass sediment bulb is for a 1914 T. Craig
- First Name: Craig
- Last Name: Luton
I won’t be there this weekend, I live on the other side of the states in Montana in the the rocky mountains
- Last Name: Hatch
Shay I was saying is there was a bucket full of them at the Meadows auction last Saturday. Somebody bought them.
The 1914 one is the most common. It has the hex at the top to help with screwing it into place.
- Last Name: Debaugh
- * REQUIRED* Type and Year of Model Ts owned: 1910 Tourabout
I have a brass 14 $50 plus postage… Larry Debaugh
- First Name: Joe
- Last Name: Bell
found a brass sediment bulb will be at hershey light pole 41.
The new repro from Snyder's seems well made - I've installed several and no leaks !
