Early Brass Speedometers
Topic author - Posts: 140
- Last Name: Debaugh
- * REQUIRED* Type and Year of Model Ts owned: 1910 Tourabout
I have 100’s of speedometers of all manufacturers restored and unrestored, mounting brackets, swivels, gears and cables. Will bring some to Hershey, CM 30-40 , what do you need. Larry
- First Name: Michael
- Last Name: Bunner
- * REQUIRED* Type and Year of Model Ts owned: 1912 Torpedo Roadster 1917 Smith Form-a-Truck
Re: Early Brass Speedometers
Hi Larry,
I need a 1911-12 stewart 26 with bracket and cable. I also need the 60T??? Gear… i have the swivel.
If you have something like that at Hershey i’ll look it over.
Thanks,
Michael
Thanks,
Michael
I’ll have them there… thanks
- First Name: T
- Last Name: Gates
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1926 Fordor
Please explain "restored"....exterior cosmetics? Interior gears, etc. so they work properly? One or the other or both? Thanks.
If restored it has been opened ,cleaned , adjusted and polished . What’s most important to proper operation is the correct wheel and swivel gear larry
- First Name: Nick
- Last Name: Rein
How much for the stacked speedo/clock?
Any 100mph speedos?
Thanks!
Any 100mph speedos?
Thanks!
That’s a Jones with a Jones clock, it keeps good time $1400
- First Name: Bill
- Last Name: Everett
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1914 Touring, 1912 Roadster PickUp in process
- Board Member Since: 2011
E-Mail sent.
