Bridge Washers
Bridge Washers
Post by Original Smith » Sat Oct 04, 2025 6:57 pm
The current bridge washer offerings are not made correctly. They got the thickness and shape correct, but didn't do the stamping correctly. Why? There is a round stamping around the stem hole to help the bridge washer seat on the tube. Is there anyone anywhere, that is capable of doing this?
First Name: Henry
Last Name: Lee
Re: Bridge Washers
Post by Henry K. Lee » Sat Oct 04, 2025 7:26 pm
Simple..., use a correct piece of round stock, a correct "catch" at the bottom and do it in a hydraulic press!
Re: Bridge Washers
Post by Scott_Conger » Sat Oct 04, 2025 7:44 pm
Then watch them collect dust on a shelf!
Adam
First Name: Adam
Last Name: Doleshal
Re: Bridge Washers
Post by Adam » Sat Oct 04, 2025 7:53 pm
There are plenty good used originals available for much less than a good reproduction would cost even if it was available. If you buy four you have a lifetime supply so why should anyone make them?
First Name: john
Last Name: karvaly
Re: Bridge Washers
Post by speedytinc » Sat Oct 04, 2025 8:03 pm
My take.
Originally the groves in the bridge washer clamped the tube stem together to hold the stem & be leak proof. Very effective.
Today the metal stems are vulcanized to piece of rubber & vulcanized or glued to the tube. The bridge washers no longer has to function to seal. No need for the circular groves to clamp the tube to the stem.
Re: Bridge Washers
Post by Steve Jelf » Sat Oct 04, 2025 11:12 pm
What Adam said. There are good originals still around. It should be pretty easy to find a few without spending a fortune. A WTB ad or two should do it.
Last Name: Strange
Re: Bridge Washers
Post by CudaMan » Sun Oct 05, 2025 5:18 pm
The Model A bridge washers available from the vendors have the proper stamping, but the wrong outer shape. They can be cut down and de-burred to match the shape of Model T bridge washers. Why a supplier can't do the last step to get the proper outer shape is a mystery. :)
Re: Bridge Washers
Post by Allan » Sun Oct 05, 2025 7:57 pm
You will need to match the hole to the size of the valve stems. The smaller holes to suit the smaller stems on T tubes are more scarce.
