Timer Question
Last Name: Juhl
Timer Question
Post by Oldav8tor » Thu Jul 04, 2019 8:39 pm
I'm prepping my rebuilt engine to get it ready to install in my T. I went to put my New Day timer on and have a question. Since the engine came from the rebuilder without a timer, I don't know which way to put the brush on the camshaft. Since the hole for the retainer pin goes all the way thru it's possible to install the brush 180 degrees off. I'd just as soon get it right the first time :D
Is there a easy way to determine the correct position for the brush on the camshaft?
Tony_H
First Name: Tony
Last Name: Howard
* REQUIRED* Type and Year of Model Ts owned: 1926 Tourer 1925 Coup
Re: Timer Question
Post by Tony_H » Thu Jul 04, 2019 9:14 pm
I imagine the simplest thing to do is set No 1 so it's just past TDC on firing stroke and see what position the brush contacts No 1 on the commutator.
Government - because people struggle to ruin their lives by themselves
Last Name: Juhl
Re: Timer Question
Post by Oldav8tor » Thu Jul 04, 2019 9:51 pm
Soooo..... to find TDC on the firing stroke I need to determine when both valves are closed?
First Name: Dallas
Last Name: Landers
Re: Timer Question
Post by Dallas Landers » Thu Jul 04, 2019 9:54 pm
Pul #1 plug and put your finger over the hole. When you feel air rushing out #1 is on its way up to TDC. I use a piece of weed eater string to know when I on TDC
Re: Timer Question
Post by Norman Kling » Thu Jul 04, 2019 9:57 pm
Easy, just put your thumb in the spark plug hole and turn the crank. When you feel the compression, you know it is coming up on compression and when it reached the top it is at top dead center. You can double check to see if both valves are at closed at that point. If your crankshaft is drilled properly, the pin through the pulley should be straight across at top dead center and you pull it just a few degrees past that point to set the timing.
Last Name: Juhl
Re: Timer Question
Post by Oldav8tor » Thu Jul 04, 2019 10:48 pm
Sheeesh... a senior moment. I use the same technique when doing compression tests on an airplane engine. I guess I'm just trying to make things more complicated.
Re: Timer Question
Post by TRDxB2 » Thu Jul 04, 2019 11:50 pm
I hope this answers the initial question "I don't know which way to put the brush on the camshaft."
