An auxilery transmission question?
LittleTimmy52
First Name: Lucas
Last Name: Milatti
* REQUIRED* Type and Year of Model Ts owned: 1917 Model T Touring
Board Member Since: 2025
Post by LittleTimmy52 » Mon Nov 17, 2025 6:30 pm
I like the idea of getting an auxiliary transmission on my model t like a warford or similar. But I want your opinions on these aux transmissions? an overdrive and underdrive would be nice for going faster and slower but still in high gear, but a lot of work goes into putting one in, and it will probably make my empty wallet die with just the thought of the cost. Should I save up and get one and tack it on? should I just forget about it? is getting an old crashbox and restoring it to speck worth it for the feel over using the constant mesh reproduction warford? is there too much a difference in feel anyways? I mean it is not going to happen any time soon if I go with it, but the general consensus of this forum would be nice in guiding my far future decision.
Thanks.
Re: An auxilery transmission question?
Post by TXGOAT2 » Mon Nov 17, 2025 6:55 pm
My choice would be a KC Warford. Driveshaft mods must be done correctly with any Warford-type auxiliary. If I added one, I'd get spare driveshaft parts and send them to the KC people to modify.
walber
First Name: Walt
Last Name: Berdan
Post by walber » Mon Nov 17, 2025 7:25 pm
If the KC Warford fits your budget, go for it. The advantage of easy shifting would be real nice. Old style auxiallary transmissions take some getting used to when shifting on the fly. Initial investment lower with an early transmission if you find a good one. I run a Chicago, similar concept as 3 speed Warford and love it in my speedster.
Whichever way you go, get brakes that work at the rear wheels. Angel gear (true nuetral) can kill you.
LittleTimmy52
First Name: Lucas
Last Name: Milatti
Post by LittleTimmy52 » Mon Nov 17, 2025 7:32 pm
would you happen to know how much the investment of getting and fixing an old warford/similar is? Because I tend to go for the "fun" (difficult) options, I tend to lean in the direction of the crash box.
Post by TXGOAT2 » Mon Nov 17, 2025 7:38 pm
The early units had spur gears with no synchros. It's possible to shift without grinding gears if the throttle and gearshift are handled properly. It's also possible for the vehicle get rolling so fast downhill in neutral that you may not have enough engine RPM to get back into gear, leaving you with little or no braking ability when you need it most. The KC units do not have these shortcomings and they ought to be much quieter.
Post by TXGOAT2 » Mon Nov 17, 2025 7:41 pm
You can get an idea of what driving with the early Warfords is like if you have access to a circa 1950 Ford pickup or truck with a 4 speed transmission. Straight cut gear teeth and no synchromesh.
mtntee20
First Name: Terry & Sharon
Last Name: Miller
Post by mtntee20 » Mon Nov 17, 2025 7:46 pm
Lucas,
I have a KC Warford. I HIGHLY RECOMMEND it. There are advantages not widely advertised. 3 Speeds, TRUE NEUTRAL, easy to shift, runs smooth. KC warford will shorten your drive line for free. I believe they will do the drive line tube as well, but I'm not sure on that. You will have to shorten the radius rods.
I particularly like the True Neutral. In neutral, it allows you to start the engine WITHOUT any forward creep or worry. The engine starts so much easier with less load on the starter and/or the battery.
I realize it is expensive. I feel the benefits make it worthwhile.
Good Luck.
kevinf
First Name: Kevin
Last Name: Fielding
Post by kevinf » Mon Nov 17, 2025 7:57 pm
Quick search on e-bay will show you several originals for sale at quite a price range.
Hope that helps,
Kevin
Last Name: Juhl
Post by Oldav8tor » Mon Nov 17, 2025 8:32 pm
I suggest you sit in a car with a Warford. I'm a big guy with big feet and there's just too little room for me to ride comfortably with the standard pedals and levers plus the warford shifter. A Ruckstell with the lever mounted on the far left works better for me.
walber
First Name: Walt
Last Name: Berdan
Post by walber » Mon Nov 17, 2025 9:36 pm
A foot throttle comes in real handy with any of the auxiliary transmissions. The straight gears need rev matching to avoid ugly sounds.
It seems an OK 3 speed auxilliary box near me is typically in the 500 to 600 range. Condition obviously matters.
BTW, Warfords come in iron and aluminum cases and while many are three speed there are also 2 speed versions.
If you live in flatland country, a Warford or similar in overdrive will let you cruise somewhat faster without over reving the engine. Again brakes are a good thing.
Folks dealing with hills or mountains frequently find a Ruckstell 2 speed rear axle a better alternative as you get an intermediate gear between T low and T high. Again, brakes at the rear wheels are highly recommended as Ruckstell axles have been known to find neutral. They shouldn't have neutral but wear or poor ajdustment can make it possible.
The model of T you have and how you plan to use the car and what changes you make can open many considerations.
A stock Model T is a pleasure to drive if you can get away from modern traffic. If you are new, I highly reccomend to start with what Henry had in mind and get used to driving and enjoying it. You may well find that you really like it that way. Most of the folks on this forum prefer near or completely stock T's.
I had a lot of fun with a dead stock '25ish touring car for many years where the only changes were improved rear brakes and a distributor. Later I was bitten by the speedster bug, a totally new adventure.
LittleTimmy52
First Name: Lucas
Last Name: Milatti
Post by LittleTimmy52 » Mon Nov 17, 2025 9:51 pm
Well I drive the thing around town, it's residential grid but it doesn't stretch to far, the grid is boxed in by 40-50 mph roads. It would be nice to be able to cruise faster than 30mph to get from my grid to the next one in a safer manner. Going below the speed limit is a disaster waiting to happen here in Florida. That's why I'm giving this aux transmission thing a good think over. Well so I can save up for one.
LittleTimmy52
First Name: Lucas
Last Name: Milatti
Post by LittleTimmy52 » Mon Nov 17, 2025 10:37 pm
Is there a such thing as a rukstell but with an overdrive instead of an underdrive? They seem easier to get installed and I really just need a overdrive, an underdrive is nice but not necessary for my goals for now. The only issue is I've never heard of an overdrive rukstell.
Post by Allan » Tue Nov 18, 2025 12:34 am
You can achieve an overdrive with a Ruckstell by fitting a taller rear axle gears etc like 3:1 but thiswill seriously compromise your braking. Sometimes woah is more important than go!
kelly mt
Last Name: Kelly
Post by kelly mt » Tue Nov 18, 2025 2:02 am
I'm running three Ruckstells and a KC Warford. The KC Warford is the hot set up. If you drive a lot, you'll love how the car operates.
Loftfield
First Name: Thomas
Last Name: Loftfield
* REQUIRED* Type and Year of Model Ts owned: 1912 Touring, 1912 Express Pick-up
Post by Loftfield » Tue Nov 18, 2025 7:40 am
OK, the hobby is big enough to accommodate everyone, but I always wonder why folks want to make a Model T modern? If you need three speeds then get a Model A or god forbid a Chevy. The fun of Model T is that it is a Model T. Enjoy the antique automotive engineering. When asked how fast my car will go I always answer with two responses. It will go 45 but it only has brakes for 32 as Allan from Down Under says. Nonetheless, I feel comfortable at 40, should get you safely from one neighbourhood to the next.
LittleTimmy52
First Name: Lucas
Last Name: Milatti
Post by LittleTimmy52 » Tue Nov 18, 2025 8:06 am
Modern is not the goal, I agree in that fun is the t it self, but when 40mph means 60 to the average Floridian driver it's hazardous to go 30. Dosent going 40 start breaking things especially in the transmission? I mean if I can push it I don't need an aux trans, just I thought it turns the gears into dust going past 30.
Will
First Name: Will
Last Name: Copeland
* REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
Post by Will » Tue Nov 18, 2025 8:29 am
I'm glad this thread popped up, As I'm getting ready to install a KC Warford when they come available. Iv already bought and shortened that a spare driveshaft and torque tube so that is ready to go. I was getting ready to post a thread looking for different opinions on the transmission. How many installed there transmissions with the frame support's? I agree about the cost. I'm converting to rear disk brakes to get ready for the Angle gear just in case and the kit alone is just under to $700.00. Of course that will be on top of the price of the transmission its self which is going be a little over $3000.00. But there's no price on safety. There is a fellow in the next town down from me that has a Warford and the stick shift is close to the seat so lots of room for big feet. One thing I will mention that is if you want a new Warford you need to get yourself on the list or you may not get one. Call Layne Machine Works at 816-520-8522. I was told the new transmission will be ready in January.
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
love2T's
First Name: T
Last Name: Gates
Post by love2T's » Tue Nov 18, 2025 9:17 am
Couldn't agree more. Drive it a lot some say? How about 3200 miles a year? On one car alone! Sometimes half as much on the other. Stock transmission, quiet running, smooth, etc. Like Loftfield says, keeping it "authentic" basically is the fun of it. Be honest with ya, even 40 is too fast in these antiques that were designed for a max of 35 mph! 30 is perfect, she purrs like a kitten, we can enjoy the scenery better and still have time to watch out for the idjuts out there trying to kill us in these wonderful cars. But, to each his own I guess. And oldav8tor is right, if ya gotta have a Ruckstell, the LEFT side shifter is the only way to go!
Post by TXGOAT2 » Tue Nov 18, 2025 10:02 am
The stock transmission has no issues with running 40 to 50 MPH. No gears are in operation when it is in "High". A Model T roadster or touring with an engine in good condition and in good balance with aluminum pistons and 10W30 oil can run easily at speeds up to about 45 MPH for extended periods.
A KC Warford is worth the one-time cost. It will provide a suitable gear for any operating condition the car is capable of, plus a free neutral, and speeds to 50 MPH and beyond on level ground. You can shift it like a modern manual transmission, with no special skills required. You can shift it up or down, at will, for braking, hill climbing, or running fast on the open road. Or you can put it in "1 to 1" and you will have a driving experience exactly like a stock T.
For flat country, like Florida, buying and rebuilding a Ruxtel and changing to 3:1 gearing would get you some of the advantages of a KC Warford at about the same cost, or a little more. With a KC Warford, stock braking is much improved by reason of having readily available intermediate ratios between Ford Low and Ford High with no wide gap between them and no danger of getting trapped in neutral.
Personally, I would not be concerned with adding auxiliary brakes just on account of installing a KC Warford. The fact that you can shift a KC Warford up or down at will, and that getting "trapped" in neutral is not a hazard, you'd have much better braking than stock by adding one. A heavy car, or mountain driving, or heavy urban traffic, or all of the above would argue for improved braking, regardless of whether you have an auxiliary transmission or not.
Post by TXGOAT2 » Tue Nov 18, 2025 10:05 am
My car runs at 1800 RPM at about 44 MPH with 4.40/4.50 X 21 tires on Ford wire wheels. It will go a good deal faster than that, but I limit it to 48 MPH. It seems happiest at 42 MPH.
Post by TXGOAT2 » Tue Nov 18, 2025 10:13 am
"It will go 45 but it only has brakes for 32 as Allan from Down Under says..."
Allan is being generous. A stock T, especially the pre-1925 cars, has brakes for 15 MPH and tires for 5 MPH. Closed cars, even less. (32 MPH is about 50 feet per second!)
Last Name: Juhl
Post by Oldav8tor » Tue Nov 18, 2025 11:03 am
I did not buy a Model T because I wanted to drive it fast like a modern car. A Model T at 50 mph starts to feel scary and in my opinion can be unsafe, even with auxiliary brakes (I have hydraulic rear discs.) The Ruckstell gives you a gear between low and high which in my experience really helps performance in hill or mountain country, while the standard gearing is fine for 95%+ of the driving conditions I encounter.
As a previous poster mentioned, belonging to the Model T hobby does not limit you to one line of thinking. You can do what you want with your car. For me, nothing beats driving a open car at modest speeds thru a beautiful countryside, especially when I'm joined by friends doing the same thing. When driving my modern car on the freeways about the best I can do is watch the traffic and the white and yellow lines....not much fun in that.
Post by TXGOAT2 » Tue Nov 18, 2025 1:25 pm
The KC Warford provides readily accessible intermediate gears. That's a good thing for hill climbing, traffic, and improved downhill engine braking and transmission brake action. Putting the Warford in low when backing down a hill in reverse will give much improved engine braking.
Post by TXGOAT2 » Tue Nov 18, 2025 1:27 pm
Balloon tires, shock absorbers, and 5:1 steering gears make an open T very stable at 50 MPH. It's important to have round wheels that run true and that are in balance.
Will
First Name: Will
Last Name: Copeland
Post by Will » Tue Nov 18, 2025 1:54 pm
I run my 19 on open going from 30 to 35, Thats where the engine feels good anything past that and I dont like how the engine feels. I want a Warford to help keep the engine RPM's down to where it feels good and still get just a few extra MPH. I doubt I would ever go over 40 with my car. Where I'm at here in Melbourne Florida the roads are mostly straight as a string with no hills. If I move to Pa in the future the transmission will help with the mountains there
RVA23T
Last Name: C
Post by RVA23T » Tue Nov 18, 2025 2:20 pm
Since you indicated you want to neighborhood hop and not do 60 to 100 mile day trips in your T I suggest the following
more affordable upgrades:
Stromberg Carb setup.
ECCT and an I-timer and tune your coils with the software.
Make sure your valves are good and seated/adjusted properly.
I drive on the eastern half of US 58 which is in the piedmont region of VA and posted 60mph. With the above set up, my touring car will do 40 to 45 mph all day and some of the longer rolling hills will hold 30 at the top with out lugging. If I ventured further west than Danville and did more daily driving or cross country touri g, I would explore Aux trans/diff options but more so for hill climbing from a stand still or to avoiding holding low down during a climb.
Post by TXGOAT2 » Tue Nov 18, 2025 2:21 pm
I'd want a KC Warford for flatland Florida for speed and versatility, and I'd definitely want one in Pennsylvania for speed, hill climbing, and enhanced braking. Pennsylvania is mostly hilly, but it offers some of the most beautiful rural roads in the USA. For reference, a stock Model T with tires of 30" OD will run about 50 MPH at 2,000 engine RPM. A stock T engine in good condition with aluminum pistons and good balance can handle about 1800 RPM, which is about 45 MPH. An overdrive gear will allow speeds up to 55 MPH or so on level ground with no headwind. Just as important, having a gear lower than High will allow maintaining more speed on hills. With a stock Ford, you are limited to about 10 MPH in Low, and 8 MPH is better. With an intermediate gear between Ford Low and Ford High you can maintain higher speeds up steep hills and enjoy better engine braking. The ability to shift gears at will with a KC Warford would be a very useful improvement for driving in traffic, especially in hilly country.
Post by TXGOAT2 » Tue Nov 18, 2025 2:25 pm
A stock or near stock T is short on horsepower for speeds over about 45 MPH. To get good results with any transmission setup, you need an engine in good condition that is in good tune and good balance that is capable of delivering its full power.
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Tue Nov 18, 2025 2:35 pm
Hi Lucas,
To answer your question:
Not really, the closest is a Moore. See this link: https://mtfca.com/phpBB3/app.php/gallery/image/2218
It still requires shortening of drive shaft and housing and I don't know how easy they are to find.
Post by Wayne Sheldon » Tue Nov 18, 2025 5:50 pm
The problem with the Moore, and the similar Universal Gear Company two speed units? Is that most of them were made to be an underdrive, usually about a fifty percent gear reduction.
Yes, they "can" be turned around, made into an overdrive. However, that results in a very steep overdrive. I did know someone many years ago that had a Moore turned into an overdrive, in a lightweight racing car with a very strong flathead engine. And oboy was that car fast! I think he had four to one gears in the rear end. That gave him an about two to one final drive ratio.
The similar Universal Gear Company two speed units were made and sold in both underdrive and overdrive versions. The underdrive was again about a fifty percent reduction. The overdrive units were a bit steep, but not nearly one to two.
Universal Gear Company and Rocky Mountain both made "six speed" transmissions for the model T. They were actually three speed progressive shift transmissions (3 X 2 = 6). I have had two Ts with those units and they are GREAT if you can get a good one!
I have never driven a model T with one of the modern Layne transmissions, so I cannot speak to that experience. The first era auxiliary transmission I had was a big case Muncie over fifty years ago. I have had several small case Muncies and a Warford since, and love having them and using them.
I also really like driving bone stock model Ts.
Will
First Name: Will
Last Name: Copeland
Post by Will » Tue Nov 18, 2025 7:13 pm
I'm told that the new Layne transmissions are synchromesh gears. Again, If you want one you need to call them and get on the list as they sell out fast
Post by Allan » Tue Nov 18, 2025 9:48 pm
The beauty of the Layne transmission is the overdrive and underwrite they provide, on top of the easy shifting. If you like, it can be set up to drive your T in standard Ford gearing
Gleaner
First Name: ED
Last Name: LARSON
Post by Gleaner » Wed Nov 19, 2025 5:06 pm
Henry knew what he was doing. Keep it stock and enjoy your car. My Dad was hauling in T’s back in the 50’s so when I was born in 1960 I grew up with model T’s. I would hate to think of all the Ruxtells we sold to guys insisting that they wanted that overdrive! You could not convince them that they were underdrives.
As I said I keep my T’s as Henry designed them. Some say “But the fenders shake”. Friend the fenders shook coming off the assembly line. That is why you could buy a new dependable new car for $325. God Bless Henry Ford!!!!
Last Name: Gregush
Post by Mark Gregush » Wed Nov 19, 2025 8:12 pm
Ya and that is why Henry approved of the Ruckstell and added wiper, rear view mirror and brake light later. He knew there was a short coming with the missing middle gear.
Post by TXGOAT2 » Wed Nov 19, 2025 8:36 pm
Increasing car weight and lower engine power, combined with increasing traffic congestion, made the 2 speed less adequate as time went on.
Post by TXGOAT2 » Wed Nov 19, 2025 8:44 pm
A Ruxtel with 3:1 ring & pinion makes for a fast T, and you also get a granny low and a useful intermediate gear.
With a 3:1 ring and pinion:
(1) Ford Lo + Ruxtel Low
(2) Ford Low +Ruxtel Direct
(3) Ford High + Ruxtel Low
(4) Ford High + Ruxtel Direct (3:1 final)
CamMan
Last Name: Young
* REQUIRED* Type and Year of Model Ts owned: '26 Tudor, '22 speedster, ABC/Rajo
Post by CamMan » Mon Nov 24, 2025 1:16 pm
I haven't seen anyone mention the problem with gear ratios in original 3 speed auxiliary transmissions. Most of the ones you find were for trucks and the ratios are much wider that what you want for a car. I restored a Muncie and ran it in my speedster. With a standard 3.64 rear the overdrive gives a very tall 2.6 ratio. I installed it with a 4:1 rear which gives a more reasonable 2.9 in overdrive, but then underdrive is at 7.2 which is far too low (5.5 to 6 is better) and not much different from overdrive-low at 7.9 . The gears in an original Warford and Jumbo Giant are similar. I finally went back to a Ruckstell and a separate overdrive which is not period but small and not visible unless you crawl under the car. Warford made a 2 speed overdrive, but they a hard to find.
Craig Leach
First Name: craig
Last Name: leach
Post by Craig Leach » Mon Nov 24, 2025 2:37 pm
Auxiliary brakes are a must with any Aux gearing. 3:1 with a Ruckstell will do the job. If you go with a Warford UDO & you dont have a strong
engine overdrive is tuff to pull with stock gears. I would suggest a 10 tooth pinion as stated before. A Muncie has a reverse that is handy & you
can use reverse & reverse peddle & get a super low gear for parades if needed. Adding a foot throttle is a super good plus when it comes to
shifting even with a Ruckstell.
Craig.
walber
First Name: Walt
Last Name: Berdan
Post by walber » Mon Nov 24, 2025 2:45 pm
Larry,
I found that with my Chicago transmission. Standard rear gears made for a higher ratio than I like in overdrive. They were fine on the flat but not so good on hills and mountains. Like you, I swapped to 4 to 1 rear gears and they work great for me. Will still take me we over 60 (i.e. faster than I need) with good power in my prefered highway speeds of 55 or so.
OK, fear mongers - I have 4 wheel hydraulic brakes and shocks on all 4 corners with 21" T wire wheels and dynabeads. No, I am not out to kill myself or anyone else with this speedster.
Walt
Post by TXGOAT2 » Tue Nov 25, 2025 9:39 am
Check the ratios available with the KC Warford.
CamMan
Last Name: Young
Post by CamMan » Tue Nov 25, 2025 10:26 am
When Elmer Layne was developing the KC Warford there was a lot of discussion on the forum with many people encouraging a closer ratio box. They are much better than the original truck ratios.
Post by TXGOAT2 » Tue Nov 25, 2025 4:44 pm
Layne KC Warford ratios with stock Ford 3.64 ring & pinion:
Ford Low, KC Low: ........18.4: 1
Ford Low, KC Direct: .....10.0: 1
Ford Low, KC Overdrive....8.3: 1
Ford High, KC Low..........6.67:1
Ford High, KC Direct: .... 3.64:1
Ford High, KC Overdrive..3.02:1
You will also have 3 different reverse ratios to choose from: Low, Stock, and an OD Reverse. (Not recommended)
