Starter Noise
First Name: Adrian
Last Name: Whiteman
Starter Noise
Post by A Whiteman » Sun Dec 07, 2025 4:12 pm
I recently reconditioned my starter.
It runs smooth and the shaft is straight and runs true (no bends or wobbles) on the test bench.
It installed nicely and when the starter button was pushed it engaged and cranked the engine well,
..... however ......
When the starter button is released (without the engine starting) it makes a bad 'graunch' as the bendix disengages. Now It should not do that at all!
No 'bad noise' on engagement and crank, only on release.
I have replaced the Bendix with a new one, same issue.
Next steps: 1) I will swap out with another starter (why not), and 2) examine the ring gear.
Any ideas what causes a graunch on disengagement??
Thanks for your suggestions.
Re: Starter Noise
Post by Jerry VanOoteghem » Sun Dec 07, 2025 4:58 pm
It all hinges on just what a "graunch" is. :)
First Name: john
Last Name: karvaly
Re: Starter Noise
Post by speedytinc » Sun Dec 07, 2025 4:59 pm
Is the bendix cover an original? Repop covers are smaller ID & if not centered can be hit by the head of the drive head bolt.
Try a brief crank with the cover removed to exclude the cover.
Briefly is key in that you will dump a lot of oil thru the missing cover opening.
Moxie26
Last Name: Jablonski
Re: Starter Noise
Post by Moxie26 » Sun Dec 07, 2025 5:24 pm
Are the four starter mounting screws tight ?
Last Name: Tannehill
Board Member Since: 2002
Re: Starter Noise
Post by JTT3 » Sun Dec 07, 2025 7:38 pm
Do you use a six volt battery or something else?
First Name: Adrian
Last Name: Whiteman
Re: Starter Noise
Post by A Whiteman » Sun Dec 07, 2025 9:10 pm
Hmm, could be a 'graunch grounch or maybe a bit more of a grruumm graunch ;-)
Yes, all original parts and cover
Yes all tight
It is a 12v converted starter, not 6v with 12v in it.
No, I have not had this problem before the refurbishment
Moxie26
Re: Starter Noise
Post by Moxie26 » Sun Dec 07, 2025 9:14 pm
If your 12 volt converted starter is a new acquisition, maybe it's going to be on its return trip for fixing ?
Re: Starter Noise
Post by JTT3 » Mon Dec 08, 2025 12:02 am
Adrian the T starter has to have a different wiring & bus cut to convert it to a12 volt starter that you can safely use on a T. You might consider Jeff as a source. He restores them and may be able to help you check to see if it was done correctly. If you have another 6 volt starter you could challenge the issue with the 6volt starter to see if the problem goes away. I’m not saying stick with 6 volt but rather get advice from Jeff on what you actually have concerning the 12 v starter.
First Name: Adrian
Last Name: Whiteman
Re: Starter Noise
Post by A Whiteman » Mon Dec 08, 2025 1:46 am
Thanks John, yes the starter is rewired and modified bus, we have been using this solution here for many years and across a lot of cars with no problems ... until this time ... :-0
